Tempest GP27U image number 0
Tempest GP27U image number 1
Tempest GP27U image number 2
Tempest GP27U image number 3
Tempest GP27U image number 4
Tempest GP27U image number 5
Tempest GP27U image number 6
Tempest GP27U image number 7
Tempest GP27U image number 8
Tempest GP27U image number 9
Tempest GP27U image number 10
Tempest GP27U image number 11
Tempest GP27U image number 12
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Tempest GP27U
Visuals Beyond Limits
Tempest GP27U
Experience truly immersive HDR performance like never before with the brand-new Tempest GP27U MiniLED monitor with 576 local dimming zones. Paired with a Quantum Dot 4K resolution panel with an extremely fast 160Hz refresh rate, the GP27U is the perfect next-level upgrade for your setup.
U.S. Shipping:
Ships from California
Price reduced from $799.99 to $749.99
DEEP BLACK PERFORMANCE
Thanks to MiniLED technology, local dimming zones are even smaller and more granular than ever before. With local dimming activated you can obtain extraordinary HDR performance with a contrast ratio of 50,000:1.
QUANTUM DOT VISUAL BRILLIANCE
Using a quantum-dot enhancement film, colors are more vibrant and can emit an even more precise amount of light, leading to stronger color reproduction and wider color gamut, making it perfect for color accurate work.
BRIGHTEST SHINE
BRIGHTEST SHINE
Reach a new level of clarity for everything you watch. MiniLED's improved display technology brightens whites and darkens blacks for an HDR picture that has an unprecedented level of picture quality. The Tempest GP27U can reach 600 nits of peak brightness in SDR mode, or 1200 nits in HDR mode. This is how MiniLED shows all your favorite content in a whole new light.
CUTTING EDGE SPEED
CUTTING EDGE SPEED
Tempest GP27U uses the latest Ultra-Speed IPS panels which is up to 4x faster than traditional IPS panels. Combined with carefully tuned overdrive profiles, the pixels transition faster to other colors and scenes, while minimizing overshoot for exceptionally smooth picture quality with significantly less motion blur or smearing. Not satisfied with any of the overdrive presets? For the first time, you can completely customize the overdrive level of your monitor within the OSD menu from values 0 to 100 for an even more fine-tuned experience.
EASY ON THE EYES
EASY ON THE EYES
Protect your eyes from potentially harmful blue light with our Low Blue Light Mode. The Tempest MiniLED series are also flicker-free*, further reducing any eye strain and allowing you to get more work or gaming done.
*flicker-free is only when local dimming is not enabled.
FULL BANDWIDTH HDMI 2.1
With two full-bandwidth HDMI 2.1 ports, equivalent to 48Gbps, the Tempest GP27U completely supports consoles like the Xbox Series X and PS5 at 4K resolution, 120Hz refresh rate without the need for any Display Stream Compression (DSC), making it a future-proof monitor for years to come.
CONNECTION MASTER
KVM SWITCHER INTEGRATION
CONNECTION MASTER
With a built-in KVM switch in the Tempest Monitor series, you can easily control an extra device such as a laptop, another desktop, tablet, or a phone using only a single set of a keyboard and mouse. With a simple toggle in the OSD menu, you can seamlessly swap controls to your second device for ultimate multitasking.
MAKE IT YOUR GAME
MAKE IT YOUR GAME
MAKE IT YOUR GAME
MASTER AGILITY
MASTER AGILITY
With a wide range of adjustability, the Tempest GP27U can be positioned to the way you want it exactly.
Tilt: -5° to +20°
Height Adjustment: 0-110mm
Swivel: -15° to +15°
Pivot: 0° to ±90°
COOLER MASTER UNIQUE DESIGN
With the Halo ring as the base of the stand, the Tempest GP27U features a design that is not only sleek, but also with a hint of flair. For those who want a clean aesthetic with minimal branding. the Tempest MiniLED series monitors are the perfect addition to your setup.
AMPLE CONNECTIVITY
AMPLE CONNECTIVITY
• 1 x DisplayPort
• 2 x HDMI 2.1
• 2 x USB Type A
• 1 x USB Type C (supports 90W PD charging output)
• 1 x 3.5mm Headphone Jack
  • Product Number CMI-GP27-FUS
  • Screen Type Flat Series
  • Ratio 16:9
  • Screen Size 27"
  • Panel Ultra-Speed IPS 1.07B colors w/Quantum Dot
  • Resolution UHD 3840x2160
  • Refresh Rate 160 Hz
  • Contrast Ratio 1000:1
  • Brightness 600 nits (SDR), 1200 nits (HDR Peak)
  • DisplayHDR1000 Compatible
  • Color Gamut Adobe RGB 99%, DCI-P3 98%
  • I/O - DP 1
  • I/O - HDMI 2.1 2
  • I/O - USB Type C 1 (PD 90W + DP ALT + USB data)
  • I/O - USB Type B 1
  • I/O - USB 3.2 Type A 2
  • I/O - Speaker 2 (3W)
  • Local Dimming MiniLED 576 zone
  • VRR Technology Adaptive Sync, FreeSync Range: Yes, G-Sync Range: Yes
  • Response Time 1ms
  • Overdrive Technology Yes
  • Lighting Rear Cover Lighting
  • Delta E <2 Yes
  • Firmware Update Yes (USB)
  • Power Consumption 47.7W*
  • VESA 100x100 mm
  • Height Adjustment 0-110 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment ±15°
  • Pivot Adjustment 0° ±90°
  • Product Gaming Monitor
  • Monitor Series GP Series
  • Note * Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Panel Type IPS
