Tempest GP2711 image number 0
Tempest GP2711 image number 1
Tempest GP2711 image number 2
Tempest GP2711 image number 3
Tempest GP2711 image number 4
Tempest GP2711 image number 5
Tempest GP2711 image number 6
Tempest GP2711 image number 7
Tempest GP2711 image number 8
Tempest GP2711 image number 9
Tempest GP2711 image number 10
Tempest GP2711 image number 11
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Tempest GP2711
Dive Into The Gaming World
Tempest GP2711
The Tempest GP2711 is a marvel of technology and is tailored to meet the high standards of avid gamers and demanding creative professionals. Adopt Cooler Master Innovation, with unique cooling design to boost 30% more durability. Featuring Mini LED, QHD resolution, and a 165Hz refresh rate, it elevates the gaming and creative experience. Enhanced with Quantum Dot technology, it boasts an impressive 99% sRGB and 95% DCI-P3 color spectrum.
U.S. Shipping:
Ships from California
Price reduced from $499.99 to $379.99
OPTIMIZED COOLING DESIGN
Featuring Cooler Master's unique heatsink and a thermal back cover design. the GP2711 ensures enhanced cooling without the need for fans. This reduces the main chip's temperature by “5°C, extending product durability by 30%. Experience unmatched temperature stability during long work or play sessions. Plus, benefit from our 4-year warranty.
Discover
HIGH CONTRAST, DEEP BLACKS
Our VA panel, with the latest Mini-LED technology, provides an ultra-high contrast visual experience in HDR. In HDR+ local dimming mode, it can achieve over 3,000,000:1 contrast*.
* Based on LAB testing
VA PANEL WITH MINI LED
While standard Mini-LED monitors suffer from low contrast and pronounced halo effects, the GP2711 offers high contrast with minimal halo problems.
TOTAL VISUAL BRILLIANCE
Using a quantum dot enhancement film, the GP2711 offers brighter, more vibrant colors with exceptional color reproduction, covering 93.5% of the Adobe RGB and 95% of the DCI-P3 color gamut ranges.
DETAILS APLENTY
DETAILS APLENTY
The QHD resolution not only offers sharper visuals, but also provides more screen space, making multitasking a breeze and gaming more immersive.
SPEED AND PRECISION MPRI
GP2711 utilize a fast 165Hz panel along with an ultra-responsive 1ms (MPRT) / less than 4ms GtG response time that is carefully calibrated for optimal overdrive performance.
ULTRA-SMOOTH REALISM
FreeSync ensures smooth, lifelike gameplay that accurately reproduces a level of realism to everything you play. By synchronizing the frames outputted from the GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is smoother than ever.
ELITE-LEVEL COLOR ACCURACY
Our monitors are hand-calibrated at the factory, promising impeccable color reproduction with a delta E ≤ 2*. Witness content as the creator envisioned.
* sRGB mode
EASY ON THE EYES
EASY ON THE EYES
With TUV Certificate hardware-enabled Low Blue Light Mode and Flicker-Free technology, the GP2711 is gentle on the eyes, minimizing fatigue as you get more work or gaming done.
CONNECTIVITY OPTIONS
Connect your devices with I/O ports consisting of:
• HDMI 2.0 x 2
• DP 1.4 x 1
• Type-C x 1 (DP Alt Mode & PD15W)
• USB Type-B 3.0 x 1
• USB Type-A 3.0 x 2
• 3.5 mm Audio Out x 1
• Speaker 2W x 2
  • Product Number CMI-GP2711
  • Screen Type Flat Series
  • Ratio 16:9
  • Screen Size 27"
  • Panel VA 16.7M w/ Quantum Dot
  • Resolution 2K QHD 2560x1440
  • Refresh Rate 165 Hz
  • Contrast Ratio 3000:1 (Typ.) / 3,000,000:1 (HDR)
  • Brightness 600 nits (Typical)
  • HDR HDR1000 Compatible
  • HDR Peak Brightness 1500 nits
  • Dimming Zones 576 Zones
  • Color Gamut DCI-P3 95% (CIE 1976), Adobe 93.5%, sRGB 99%, 130% Area Ratio
  • Color Gamut 130% Area Ratio
  • I/O - DP 1.4 1
  • I/O - HDMI 2.0 2
  • I/O - USB Type C 1 (PD 15W + DP ALT)
  • I/O - USB 3.0 Type B 1
  • I/O - USB 3.0 Type A 2
  • I/O - 3.5mm Audio Out 1
  • Overdrive Technology Yes
  • VRR Technology AMD FreeSync
  • Response Time 1ms (MPRT), 4ms (GtG)
  • Eye Protection TUV Certificate Hardware Low Blue Light
  • Anti-flicker TUV Certificate Flicker Free
  • I/O - Speaker 2 (2W)
  • KVM Yes
  • Power Consumption 39W*
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Swivel Adjustment ±15°
  • Height Adjustment 0-110 mm
  • Pivot Adjustment 0° ±90°
  • Cooler Master Enhanced Cooling Design Yes
  • Product Gaming Monitor
  • Monitor Series GP Series
  • Note * Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Panel Type VA
