SickleFlow 200 ARGB image number 0
SickleFlow 200 ARGB image number 1
SickleFlow 200 ARGB image number 2
SickleFlow 200 ARGB image number 3
SickleFlow 200 ARGB
SickleFlow 200 ARGB
SickleFlow 200 ARGB
SickleFlow 200 ARGB
Choose the Most
SickleFlow 200 ARGB
Air Balance Blades
Reinforced Frame
Improved Bearing Seal
Vibrant Lighting
Addressable Gen 2 RGB
U.S. Shipping:
Ships from California
$19.99
OPTIMIZED FLOW AND PRESSURE
With a size boost and spec upgrade, the SickleFlow 200 ARGB is the newest option in our series. The reinforced frame structure and signature Air Balance fan blades reduce turbulence and noise while maintaining impressive air flow and pressure.
New Bearing Seal
Fan bearing seal improved to block dust and prevent leakage, boosting stability and lifespan.
Enhanced Fan Frame
Fortified square frame structure with added rib-support cuts turbulent flow and noise while increasing durability and efficiency.
ADDRESSABLE GEN 2 RGB LIGHTING
Addressable Gen 2 RGB allows you to customize a vast range of lighting for even more versatility.
Download MasterPlus+
  • Product Number MFX-B3DN-08NP2-R1
  • Exterior Color Black
  • Fan Dimensions (L x W x H) 200 x 200 x 25 mm / 7.9 x 7.9 x 1 inch
  • Fan Speed 0-800 RPM (PWM) ± 10%
  • Fan Airflow 102.8 CFM
  • Fan Noise Level 15.7 dBA
  • Fan Bearing Type Sleeve Bearing
  • Fan Air Pressure 1.35 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.2A
  • Fan Safety Current 0.3A
  • Fan Power Consumption 2.4W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.4A
  • Fan Weight 330g / 0.7 lbs
  • Warranty 3 years
  • Cooler Type Case Fan
  • Series SickleFlow
  • Fan Size 200
  • Number of LEDs 12pcs
