SickleFlow 120 image number 0
SickleFlow 120 image number 1
SickleFlow 120 image number 2
SickleFlow 120
SickleFlow 120
SickleFlow 120
Choose The Most
SickleFlow 120
The new SickleFlow 120 fan blades were created with larger blades and increased curvature to optimize the air flow and air pressure performance...
U.S. Shipping:
Ships from California
$4.99
SickleFlow 120, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
Enhanced Fan Frame
Sealed Bearing Structure
  • Product Number MFX-B2NN-18NPK-R1
  • Fan Profiles Non-LED
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 62 CFM ± 10%
  • Fan Air Pressure 2.5 mmH2O ± 10%
  • Fan Noise Level 8 - 27 dBA
  • Fan MTTF 160,000 Hours
  • Fan Rated Current 0.15A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.8W
  • Fan Weight 156g / 0.34 lbs
  • Cooler Type Case Fan
  • Series SickleFlow
  • LED Lighting Non-LED
  • Fan Size 120
