NR200P V3 image number 0
NR200P V3 image number 1
NR200P V3 image number 2
NR200P V3 image number 3
NR200P V3 image number 4
NR200P V3
NR200P V3
NR200P V3
NR200P V3
NR200P V3
Compact Power, Refined Design
NR200P V3
The NR200P V3 is crafted for creators, gamers, and PC DIY enthusiasts who demand both performance and style. Optimized for the latest NVIDIA 50-series GPUs, it features enhanced airflow, PCIe Gen5 support, and premium materials in a sleek ITX form factor.
Whether you're chasing high frame rates or a clean aesthetic, the NR200P V3 delivers powerful cooling and endless customization options—ready for your next-gen build.
U.S. Shipping:
Ships from California
$179.99
Next-Level Cooling, Built for Performance
Support for 240mm and 280mm AIO liquid coolers enables powerful thermal performance to handle high-end components with ease.
With optimized airflow design, your system stays cool and stable—even under heavy loads.
Serious GPU Compatibility, Future-Ready
Includes a PCIe 5.0 riser cable and supports vertical GPU installation up to 361.5mm in length and 160mm in height.
A built-in support bracket ensures rock-solid stability—even for today’s largest graphics cards.
Optimized Airflow with Removable Mesh Panels
Large mesh side panels boost airflow and help reduce dust.
Easily switch between maximum cooling or a sleek closed look—your build, your style.
Tool-Free, Hassle-Free Installation
CNC-machined aluminum side panels with magnetic latching offer seamless tool-free access.
Enjoy effortless upgrades and maintenance—while preserving a clean, minimalist aesthetic.
Support for Next-Gen Graphics Cards
Includes a PCIe 5.0 riser cable to ensure high-speed, stable GPU connectivity. Ready for the bandwidth demands of next-generation graphics cards, while enabling a clean vertical GPU installation.
Ultra-Fast Front I/O – USB 3.2 Gen 2x2 Type-C
Equipped with the latest USB 3.2 Gen 2x2 Type-C for blazing 20Gbps speeds.
Perfect for creators, gamers, and anyone who demands high-speed performance.
  • Product Name NR200P V3
  • Model Number NR200PV3-KWNN-S00
  • Exterior Color Black
  • Materials - Exterior Aluminum, SGCC Steel, Mesh, ABS Plastic
  • Material - Side panel Aluminum, Steel
  • Motherboard Compatibility Mini-ITX
  • Drive Bays - 5.25" ODD N/A
  • Drive Bays - 3.5" HDD 1 (Max. 2)
  • Drive Bays - 2.5" SSD 1 (Max. 2)
  • I/O Panel - Power-LED Color White
  • I/O Panel - HDD-LED Color N/A
  • I/O Panel - USB Ports 2 x USB 3.2 Gen 1, 1 x USB 3.2 Gen2 x 2 Type-C
  • I/O Port - Audio - 3.5mm Headset Jack (Audio+Mic) 1
  • Clearance - CPU Cooler 70 mm
  • Clearance - PSU SFX, SFX-L
  • Clearance - Graphics Card L: 361.5 mm (incl. power connector) H: 160 mm (incl. power connector) W: 78.5 mm (3.8 slots)
  • Fan Support - Front N/A
  • Fan Support - Top 2 x 120 mm / 2 x 140 mm
  • Fan Support - Back N/A
  • Fan Support - Bottom 1 x 120mm (W/O 3.5”HDD at the bottom)
  • Fan Support - Left side N/A
  • Radiator Support - Front N/A
  • Radiator Support - Back N/A
  • Radiator Support - Bottom N/A
  • Radiator Support - Left side N/A
  • Included Accessories PCIe 5.0 x16 riser cable x1
  • Included Accessories GPU holder
  • Volume (incl. Protrusions) 18.62 L
  • Dimensions (L x W x H) 378.2 x 185 x 292 mm(Incl. Protrusions), 367.2 x 185 x 274 mm(Excl. Protrusions)
  • Series MasterBox Series
  • Size Mini ITX
