MWE Gold V4 750W~1000W image number 0
MWE Gold V4 750W~1000W image number 1
MWE Gold V4 750W~1000W image number 2
MWE Gold V4 750W~1000W image number 3
MWE Gold V4 750W~1000W image number 4
MWE Gold V4 750W~1000W image number 5
MWE Gold V4 750W~1000W image number 6
The Intelligent Guardian
GPU Shield Intelligent Current Management (Patent Applied For) ​
80 Plus Gold efficiency​​
Digital Control PSU ​​
Wave-type heatsink design​​
ATX 3.1 & PCIe 5.1 Standards Support ​
Low-noise Design
Conformal Coating
10-year warranty
U.S. Shipping:
Ships from California
Automatically detects abnormal current, and alerts users through LED indicators for safer, more stable power delivery.
Digital Control IC
Engineered with digital control IC to achieve precise digital tuning of PFC and LLC, improving the overall efficiency 3% higher than previous series.
Digital Control IC
750W / 850W
750W/850W Modular Cables
750W / 850W
750W / 850W
1000W
1000W Modular Cables
1000W
1000W
Equipped with the latest standard and 12V-2x6 output connector, ready for next-gen flagship graphics cards.
Low-noise Design
Engineered to achieve a lab-level noise control to deliver quiet power operation.
Conformal Coating
Protective coating that improves durability and safeguards components in harsh environments.
10-year warranty
This unit comes with a standard limited manufacturing warranty of 10 years from the date of purchase.
  • Model 750W: MPM-75F4-AFG​ | 850W: MPM-85F4-AFG​ | 1000W: MPM-A0F4-AFG
  • Input Voltage 100 – 240 V~
  • Fan Bearing Hydrodynamic bearing
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time ≥ 11ms @ 100% Load
  • Protections SCP / OVP / UVP / OCP / OPP / OTP
  • Regulatory cTÜVus / TÜV / RoHS / CB / CE / FCC / BSMI / CCC / KCC / RCM / UKCA
  • ATX 24 Pin Connectors x1 = 1x (600mm)
  • EPS 4+4 Pin Connectors x1 = 1x (700mm)
  • PCI-E 6+2 Pin Connectors 750W / 850W: x4 = 2x (600+120mm)​ |1000W: x3 = 3x (600mm)
  • 12V-2x6(12+4 Pin) Connectors x1 = 1x (600mm)
  • SATA Pin Connectors x6 = 2x (400+120+120mm)
  • Peripheral 4 Pin Connectors x3 = 1x (400+120+120mm)
