null image number 0
null image number 1
null image number 2
null image number 3
null image number 4
null image number 5
null image number 6
null image number 7
null image number 8
null image number 9
null
null
null
null
null
null
null
null
null
null
MWE Gold 850 - V2 Full Modular
80 Plus Gold Efficiency
2 EPS Connectors
120mm HDB Fan
High Temperature Resilience
Full Modular Cabling
5 Year Warranty
Model
  • In Stock
U.S. Shipping:
Ships from California
$99.99
2 EPS Connectors
Quiet Cooling
The MWE Gold - V2 has been upgraded with an HDB fan. This fan bearing delivers quiet and effective cooling with a long lifespan, allowing users to get the most out of their PSU for years to come. A number of additional measures have been applied to the original MWE Gold in order to reduce sound output and ripple noise for a demonstrably quieter user experience.
While the original MWE Gold had a maximum operating temperature of only 45 degrees Celsius, the MWE Gold - V2 has improved upon this by delivering an additional 5 degrees to that limit. With this model, users will be able to push their power supply to 50 degrees Celsius safely. Such a high threshold greatly improves what's possible to accomplish with your PSU and your system in general. Overclocking and other high intensity applications become way more accessible when the system's power supply can take the heat.
80 Plus Gold Certified
  • Model MPE-8501-AFAAG
  • Input Current 12-6A
  • Fan Bearing HDB
  • Fan Speed 1500 RPM
  • Noise Level @ 20% 0 dBA
  • Noise Level @ 50% 17.8 dBA
  • Noise Level @ 100% 25.9 dBA
  • 80 PLUS Rating 80 PLUS Gold
  • Hold Up Time >16ms at 100% Load
  • Regulatory TUV, CE, CCC, EAC, RCM, cTUVus, FCC, BSMI, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 4
  • Series MWE Gold Series
  • Category Above 750W
  • 80 Plus Efficiency Gold
  • Watts 850W
