Mobius 120P ARGB image number 0
Mobius 120P ARGB image number 1
Mobius 120P ARGB image number 2
Mobius 120P ARGB
Mobius 120P ARGB
Mobius 120P ARGB
More Balance, More Burst
Mobius 120P ARGB
Ring Blade Design (RBD)
Pressure Air Acceleration
Absolute Acoustics
Luminescent Light Effects
Addressable Gen 2 RGB
U.S. Shipping:
Ships from California
$29.99
ANTI-VIBRATION DAMPER
ABSOLUTE ACOUSTICS
Sound output fine tuned to the optimal prominence ratio
to achieve sub 6dB noise levels without performance sacrifice.
Acoustic Testing
Anechoic Chamber for ISO 3745
• Sound Pressure: IS0-7779
• Sound Power: ISO-7779
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
  • Product Number MFZ-M2DN-24NP2-R1
  • Exterior Color Black
  • Number of LEDs 8pcs
  • Fan Speed 0-2400 RPM ± 10%
  • Fan Airflow 75.2 CFM
  • Fan Noise Level 30 dBA
  • Fan Air Pressure 3.63 mmH2O
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.18A
  • Fan Safety Current 0.35A
  • Fan Power Consumption 2.16W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.48A
  • Fan Weight 179g / 0.38 lbs
  • Warranty 5 years
