UPDATED CPU COMPATIBILITY
The Core II is compatible with all of the latest AMD and Intel CPUs
SUPPORT LGA 1851 RL-ILM SOCKET DESIGN
MasterLiquid Core II Series
Innovative design
Dual chamber pump
Optimum tubing length
Revamped fans
Updated CPU compatibility
Easy installation
Included Cryo-Fuze thermal paste
An infinity mirror pump cover gives the pump a stellar aesthetics
Upgraded design resulting in a compact cooler with superior performance
400 mm long tubing enables effortless mounting of the cooler in any orientation
The brand-new fan blades and revamped aesthetics deliver outstanding performance and a fresh look
Simplified fan connection for easy cable management
