MasterLiquid 120L Core image number 0
MasterLiquid 120L Core image number 1
MasterLiquid 120L Core image number 2
New Gen S Dual Chamber Pump
Expanded Radiator Surface
120mm Fan
Clean Classic Design
CryoFuze Performance Thermal Paste
U.S. Shipping:
Ships from California
Price reduced from $89.99 to $59.99
Cooler Master has built upon the classic MasterLiquid L Series to present a redesigned and improved release of the MasterLiquid 120L Core. Featuring new design elements that bring a classic minimalist look to the series, the MasterLiquid 120L Core represents Cooler Master’s ongoing innovative spirit.
Redesigned copper base targets heat spots with precision along with boosted water flow and pressure for enhanced cooling performance.
Expanded radiator fin surface accelerates heat dissipation for superior cooling.
120mm fan
An upgraded 120mm fan delivers optimal radiator performance.
Clean minimalist design brings a refreshed modern facelift to the pump cover.
CryoFuze thermal PASTE
Includes premium CryoFuze thermal paste for exceptional heat conductivity.
  • Product Number MLW-D12M-A17PK-R1
  • Exterior Color Black
  • CPU Socket AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket
  • Radiator Material Aluminum
  • Radiator Dimensions 157 x 119.6 x 27.2 mm / 6.2 x 4.7 x 1.1 inch
  • Pump Dimensions 81 x 76 x 47 mm / 3.2 x 3 x 1.9 inch
  • Pump MTTF >70,000 Hours
  • Pump Noise Level 12 dBA (Max)
  • Pump Connector 3-Pin
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 3.96W
  • Fan Quantity 1 PC
  • Fan Speed 650-1750 RPM ± 10%
  • Fan Airflow 71.93 CFM (Max)
  • Fan Pressure 1.86 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.26A
  • Fan Safety Current 0.37A
  • RAM Clearance N/A
  • Warranty 3 years
  • Series MasterLiquid Lite
  • Cooler Type Liquid Cooler
  • Radiator Size 120
