MasterFrame 600 image number 0
MasterFrame 600 image number 1
MasterFrame 600 image number 2
MasterFrame 600 image number 3
MasterFrame 600 image number 4
MasterFrame 600
MasterFrame 600
MasterFrame 600
MasterFrame 600
MasterFrame 600
Premium modular ATX case
MasterFrame 600
Premium open-frame ATX case designed for modular builds, extreme cooling, and total customization through the FreeForm 2.0 platform.
Price reduced from $249.99 to $199.99
MasterFrame 600
The MasterFrame 600 is a premium open-frame mid-tower chassis built for high-performance hardware, extreme cooling, and total customization. Designed with FreeForm 2.0 in mind, it supports ATX to E-ATX motherboards and offers full access to modular design files, empowering users to build and evolve without limits.
MasterFrame 600
MasterFrame 600
FreeForm 2.0
Exo-structure
The exposed frame structure enhances chassis adaptability and provides flexible configuration options for various scenarios.
Versatile & Maker-Driven
Its open source design and interchangeable panels offer endless personalization possibilities, transforming your chassis into a unique expression of style.
Flexible Motherboard Support
Supports Mini-ITX to E-ATX motherboards, offering compatibility with a wide range of builds and configurations.
Extensive Cooling Support
Can house up to eleven fans and multiple radiator sizes (up to 420mm), ensuring superior thermal performance.
Ample GPU Clearance
Accommodates graphics cards up to 485mm, offering plenty of space for high-end GPUs.
Tool-Free Panel Removal
Easily remove side panels and other components without tools for quick access and modifications during build or upgrades.
Included GPU support bracket
The included GPU support bracket prevents GPU sag and ensures stability during intense gaming or high-performance workloads, maintaining a clean and secure build.
MasterFrame Series
  • Model Number Black: MF600-KGNN-S00, Silver: MF600-SGNN-S00
  • Color(s) Black / Silver
  • Materials - Exterior SGCC Steel, Aluminum
  • Materials - Side panel (Right / Left) Tempered Glass / Aluminum
  • Dimensions (L x W x H) 531 x 261 x 544mm (Incl. Protrusions), 514 x 244 x 514 mm (Excl. Protrusions)
  • Volume 73.6 L (Liters Incl. Protrusions)
  • Motherboard Support Mini-ITX, Mini-DTX, Micro-ATX, ATX , E-ATX*, SSI-CEB* ​(*Conditional Support)
  • Power Supply Support ATX
  • PCI Expansion Slots 8
  • 5.25" Drive Bays 0
  • 3.5" Drive Bays 0
  • 2.5" Drive Bays 3
  • Pre-installed Fans - Front Mobius 140 mm x 3 (non-ARGB) - Available for Black Model Only, SickleFlow ARGB 140 mm x 3 - Available for Silver Model Only
  • Pre-installed Fans - Rear Mobius 120 mm x 1 (non-ARGB) - Available for Black Model Only, SickleFlow ARGB 120 mm x 1 - Available for Silver Model Only
  • Fan Support - Front 3x 120mm, 3x 140mm, 2x 180mm, 2x 200mm
  • Fan Support - Top 3x 120mm, 2x 140mm, 2x 180mm, 1x 200mm
  • Fan Support - Rear 1x 120mm
  • Fan Support - Side 3x 120mm, 3x 140mm
  • Radiator Support - Front 120 / 140 / 240 / 280 / 360 / 420 mm (Limit: 458 mm)
  • Radiator Support - Top 120 / 140 / 240 / 280 / 360 / 420 mm (Up to 420mm if I/O module is moved to the front panel)
  • Radiator Support - Rear 120 mm
  • Radiator Support - Side 240 / 280 / 360 / 420 mm
  • Dust Filters Top, Front, Bottom, Right side panel
  • Clearance - CPU Cooler 190 mm
  • Clearance - PSU 235 mm
  • Clearance - Graphics Card L: 485 mm (incl. power connector), H: 190 mm (incl. power connector)
  • Included Accessories GPU Support Bracket (Available for Black Model Only), GPU Support Bracket / ARGB PWM Hub (Available for Silver Model Only)
  • Cable Routing - Behind Motherboard Tray 43 mm
  • Size Mid Tower
  • Series MasterFrame Series
  • Product Sheet - MasterFrame 600 - English Edition Download
  • Product Sheet - MasterFrame 600 Black - Japanese Edition Download
  • Product Sheet - MasterFrame 600 Silver - Japanese Edition Download
  • Manual - MasterFrame 600 Download
