MasterFan A Series image number 0
MasterFan A Series image number 1
MasterFan A Series image number 2
MasterFan A Series image number 3
MasterFan A Series image number 4
MasterFan A Series image number 5
MasterFan A Series image number 6
MasterFan A Series image number 7
MasterFan A Series image number 8
MasterFan A Series image number 9
MasterFan A Series image number 10
MasterFan A Series
MasterFan A Series
MasterFan A Series
MasterFan A Series
MasterFan A Series
MasterFan A Series
MasterFan A Series
MasterFan A Series
MasterFan A Series
MasterFan A Series
MasterFan A Series
Masterfully Metal. Permanently Powered.
MasterFan A Series
• Flagship all aluminum construction
• Optional Turbo Charge Controller
• High air pressure
• Three-phase motor design
series
U.S. Shipping:
Ships from California
$39.00 - $49.99
CHOOSE YOUR CONTROL
The MasterFan A Series comes in two configurations to match how you push your system. The A120 and A140 deliver the full MasterFan A performance package out of the box — precision aluminum blades, three-phase motor stability, and sustained high-velocity airflow built for demanding builds. For those who want to go further, the A120 FC and A140 FC include a dedicated controller that puts Turbocharge mode at your fingertips — instantly overclocking your fans beyond standard speeds to unleash maximum cooling overhead on demand. Same engineering foundation. Total command over how hard you push it.
THE NEW METAL STANDARD
Engineered for extreme performance, the MasterFan A120 FC and MasterFan A140 FC reach sustained Turbocharge speeds with aluminum blades that resist warping. Both models include a dedicated controller that allows users to instantly engage Turbocharge mode for maximum cooling overhead. Delivering a massive 13.15 mmH2 O of static pressure, it excels at pushing air through tight spaces and high-density radiators where standard fans lose efficiency.
ULTRA SMOOTH OPERATION
The integrated three-phase Motor eliminates instability to ensure ultra-quiet start-up and superior, reliable performance for maximum system efficiency.
MAXIMUM PRESSURE. ZERO RESISTANCE
Exceptional air pressure is guaranteed by the MasterFan A Series' structural integrity. The premium aluminum frame and blades resist warping and maintain their precise shape at intense speeds. This sustained rigidity allows the fan to overcome the resistance of restrictive components, delivering focused, high velocity airflow that drastically reduces system temperatures.
Specifications - MasterFan A120
  • Product Number MFZ-P2NA-25NPK-R1
  • Dimensions 120 x 120 x 30mm
  • LED Profile Non-LED
  • Speed 0–2500 ± 10% RPM
  • Air Flow 76.9 CFM Max
  • Air Pressure 6.1 mmH₂O Max
  • MTTF >200,000 hours
  • Noise Level 29.7 dBA Max
  • Bearing Two-Ball Bearing
  • Connector 4-Pin PWM
  • Rated Voltage 12 VDC
  • Rated Current 0.17A
  • Safety Current 1A
  • Power Consumption 2.04W
  • Weight 305g
  • Warranty 6 Years
Specifications - MasterFan A120 FC
  • Product Number MFZ-P2NA-40NPK-R1
  • Speed 0–4000 ± 10% RPM
  • Air Flow 121.73 CFM Max
  • Air Pressure 13.15 mmH₂O Max
  • Noise Level 42.5 dBA Max
  • Rated Current 0.5A
  • Safety Current 1A
  • Power Consumption 6W
  • Weight 305g
  • Warranty 6 Years
Specifications - MasterFan A140
  • Product Number MFZ-P4NA-19NPK-R1
  • Dimensions 140 x 140 x 30mm
  • Speed 0–1900 ± 10% RPM
  • Air Flow 104 CFM Max
  • Air Pressure 3.41 mmH₂O Max
  • Noise Level 30.4 dBA Max
  • Rated Current 0.15A
  • Safety Current 1A
  • Power Consumption 1.8W
  • Weight 379g
  • Warranty 6 Years
Specifications - MasterFan A140 FC
  • Product Number MFZ-P4NA-30NPK-R1
  • Speed 0–3000 ± 10% RPM
  • Air Flow 164.4 CFM Max
  • Air Pressure 8.28 mmH₂O Max
  • Noise Level 41.5 dBA Max
  • Rated Current 0.52A
  • Safety Current 1A
  • Power Consumption 6.24W
  • Weight 379g
  • Warranty 6 Years
