MasterBox Q300L image number 4
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
Choose Your Style
MasterBox Q300L White
High Flexibility for System Building
Minimized Dimension with ATX PSU Support
Patterned Dust Filter
Clean Routing Space
Excellent Thermal Performance
Edge-to-Edge Acrylic Transparent Side Panel
Vertical and Horizontal position
$49.99
Multiple Positioning Options
Q300L White Edition
This the white edition of the award-winning MasterBox Q300L, time to get a clean pure-white build!
Modular I/O Panel
Edge-to-edge Side Panel
Fan And Radiator Support
The front supports up to two 140mm fans and up to a 240mm radiator.
The rear supports a 120mm fan or radiator and the top two 120mm fans.
All to ensure you don't have to compromise on performance.
Main Components Clearance
The MasterBox Q300L case supports CPU coolers up to a height of 159mm, graphics cards up to a length of 360mm, and power supplies up to a length of 160mm.
  • Model Number MCB-Q300L-WANN-S00
  • Color(s) White
  • Materials Steel, Plastic
  • Dimensions (L x W x H) 387 x 230 x 381mm
  • Expansion Slots 4
  • 5.25" Drive Bays 0
  • 3.5" Drive Bays 1
  • 2.5" Drive Bays 2
  • I/O Panel - Audio In / Out 1x Audio Jack
  • Fan Support - Top 2x 120mm
  • Fan Support - Rear 1x 120mm
  • Fan Support - Bottom 1x 120mm
  • Clearance - CPU Cooler 159mm
  • Clearance - GFX 360mm
  • Clearance - PSU 160mm
  • Cable Routing 28mm
  • Dust Filters Bottom
  • Size Mini Tower
  • Series MasterBox Series
