MasterBox 540 image number 0
MasterBox 540 image number 1
MasterBox 540 image number 2
MasterBox 540 image number 3
MasterBox 540 image number 4
MasterBox 540 image number 5
MasterBox 540 image number 6
MasterBox 540 image number 7
MasterBox 540 image number 8
MasterBox 540 image number 9
MasterBox 540 image number 10
MasterBox 540 image number 11
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
MasterBox 540
Game In A New Light
MasterBox 540
ARGB Ether Front Panel
Standardized ARGB Connector & Controller Included
Removable Top Panel
Rich Connectivity
Screwless & Tool-Free Design TG Side Panel
Versatile Cooling Options
Room For Upgrades
U.S. Shipping:
Ships from California
$99.99
Game In a New Light
A vivid, iridescent design spans the entire front panel of the MasterBox 540. Customizable ARGB strips radiate behind the transparent façade for a stunning display of light.
The ARGB strips can be set to match the colour scheme of the system inside with an included controller, and will also sync to the motherboard for a limitless potential for customization.
Game In a New Light
Game In a New Light
Inspired by the design of automotive lighting, the front panel houses ARGB lighting strips paired with a front diffuser.
This design element is powered by a pogo pin connector and fused to the DarkMirror finish of the façade, delivering a unique twist on conventional illumination.
Removable Top Panel
The top panel is entirely removable for improved access to the components during assembly.
Ease of use also facilitates the mounting of cooling solutions such as fans and radiators.
Rich Connectivity
Support for up to seven 120mm fans and dual 360mm radiators on the top and front panel ensure high compatibility for liquid-cooled systems.
Room For Upgrades
Support for up to a 410mm graphics card, a 165mm CPU cooler, and up to a 180mm PSU in length provides room for upgrades to stay ahead of the game.
  • Model Number MB540-KGNN-S00
  • Color(s) Black
  • Materials - Exterior Steel, Mesh, Plastic
  • Dimensions (L x W x H) 499.3 x 208.6 x 498mm (incl. Protrusions), 488.3 x 208.6 x 498mm (excl. Protrusions)
  • Volume 51.87L (exlc. Protrusions)
  • Motherboard Support Mini-ITX, Micro-ATX, ATX, E-ATX* (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Expansion Slots 7
  • 5.25" Drive Bays 0
  • 2.5" Drive Bays 4
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 3.2 Gen 2 Type C
  • I/O Panel - Other 1x Reset/ARGB button
  • Pre-installed Fans - Rear 1x 120mm 650~1800RPM SickleFlow PWM ARGB
  • Fan Support - Top 3x 120mm / 2x 140mm
  • Fan Support - Front 3x 120mm / 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 140 / 240 / 280 / 360mm (recommended maximum thickness - 55mm)
  • Radiator Support - Front 120 / 140 / 240 / 280 / 360mm
  • Clearance - PSU 180mm / 7.08" (295mm / 11.61" with HDD cage removed)
  • Clearance - GFX 410mm/16.1"
  • Power Supply Support ATX
  • Size Mid Tower
  • Series MasterBox Series
