MasterLiquid Atmos II Pro ARGB image number 0
MasterLiquid Atmos II Pro ARGB image number 1
MasterLiquid Atmos II Pro ARGB image number 2
MasterLiquid Atmos II Pro ARGB image number 3
MasterLiquid Atmos II Pro ARGB image number 4
MasterLiquid Atmos II Pro ARGB image number 5
MasterLiquid Atmos II Pro ARGB image number 6
MasterLiquid Atmos II Pro ARGB image number 7
Mesh by Design. Power by G9B V2.
• Industrial-grade 3D metal-mesh ARGB cover
• Upgraded G9B V2 dual-chamber pump
• Three MasterFan M120 ARGB fans
• Backed by a 6-year Warranty
U.S. Shipping:
Ships from California
ENGINEERED FOR PERFORMANCE. DESIGNED FOR YOU.
An upgraded G9B V2 pump, copper cold plate, and pressure-optimized fans deliver efficient, reliable cooling to keep your CPU performing at its best, even under demanding workloads.
UPGRADED G9B V2 PUMP
Refined From the Inside Out.
The dual-chamber pump improves coolant circulation and acoustic performance, with a copper cold plate and vibration-damping materials for dependable cooling.
MAKE IT YOURS
Magnetic Covers. Instant Customization.
Switch between the illuminated 3D metal-mesh cover, a clean metal-finish cover and a VRM fan cover with the quick-swap magnetic mounting system.
HIGH PRESSURE LOW NOISE
MasterFan M120 ARGB fans use magnetic-levitation bearings and pressure-optimized blades to push air through dense radiators, while ring-style ARGB adds subtle lighting.
OPTIMIZED FOR INTEL AND AMD
Put Cooling Closer to the Hotspot.
Dedicated offset mounting positions the cold plate closer to modern CPU hotspots on supported Intel and AMD platforms.
Intel LGA 1851 / 1700 / 1200 / 115x
AMD AM5 / AM4
6-YEAR WARRANTY
Built With Long-Term Confidence.
Atmos II Pro ARGB is backed by a 6-year Cooler Master warranty, giving you long-term confidence in your cooling system.
3D METAL MESH STANDOUT STYLE
Precision-cut texture. Clean ARGB lighting. Quick-swap customization.
The textured metal-mesh cover and integrated ARGB lighting bring a premium industrial aesthetic to the pump, with a magnetic fit that makes customization simple.
DESIGNED FROM THE INSIDE OUT
Every Detail. Built to Perform.
An upgraded G9B V2 pump, copper cold plate and pressure-optimized fans are paired with swappable magnetic covers for performance and flexibility.
  • Product Name MasterLiquid Atmos II Pro ARGB
  • Product number MLX-D36M-A23TA-R1
  • CPU platform support - Intel Intel® LGA 1851 / 1700 / 1200 / 1150 / 1151 / 1155 / 1156 / socket
  • CPU platform support - AMD AMD® AM5 / AM4 socket + offset bracket
  • Pump Dimensions 92.5 x 87 x 39 mm (3.6 x 3.4 x 1.5 inch)
  • Radiator - Material Aluminum
  • Radiator - Dimensions (LxWxH) 394 x 119.2 x 27 mm (15.5 x 4.7 x 1.1 inch)
  • Water pipes - Length 400 mm
  • Pump - Noise levels(Max) 25 dB(A)
  • Pump - Features Non-LED
  • Pump - Speed 3400 ± 300 RPM
  • Pump - MTTF > 210,000 hours
  • Pump - Rated voltage 12 VDC
  • Pump - Power 3.84 W
  • Pump - Connector 3-Pin ARGB + 4-Pin PWM
  • Flex-Kit - Name VRM Fan
  • Flex-Kit - Color Black
  • Flex-Kit - Dimensions 85.0 x 78.5 x 25.5 mm (3.4 x 3.1 x 1 inch)
  • Flex-Kit - Features NON LED
  • Flex-Kit - Quantity(pcs) 1 PCS
  • Flex-Kit - Wire length 1000 mm
  • Flex-Kit - Speed 690 ~ 4000 ± 10% RPM
  • Flex-Kit - Airflow(Max) 15.8 m³/h (9.3 CFM)
  • Flex-Kit - Air Pressure(Max) 2.8 mmH₂O
  • Flex-Kit - Noise levels(Max) 36 dB(A)
  • Flex-Kit - MTTF > 50,000 hours
  • Flex-Kit - Bearings Dynamic-Loop Bearing
  • Flex-Kit - Connector 4-Pin PWM
  • Flex-Kit - Rated voltage 12 VDC
  • Flex-Kit - Rated current 0.15 A
  • Flex-Kit - Safe current 0.25 A
  • Flex-Kit - Power 1.8 W
  • Fan - Dimensions 120 x 120 x 30 mm (4.8 x 4.8 x 1.18 inch)
  • Fan - Features Addressable GEN 2 RGB
  • Fan - Quantity(pcs) 3 PCS
  • Fan - Speed 0 ~ 2300 RPM± 10%
  • Fan - Airflow(Max) 127.8 m³/h (75.2 CFM)
  • Fan - Air Pressure(Max) 5.4 mmH2O
  • Fan - Noise levels(Max) 27 dB(A)
  • Fan - MTTF > 200,000 hours
  • Fan - Bearings magnetic-levitation bearings
  • Fan - Connector 7-Pin PWM + ARGB
  • Fan - Rated voltage 12 VDC
  • Fan - Rated current 0.1 A
  • Fan - Safe current 0.2 A
  • Fan - Power 1.2 W
  • Warranty 6 years
