Hyper 212 Halo SF6 Ryu image number 0
Hyper 212 Halo SF6 Ryu image number 1
Hyper 212 Halo SF6 Ryu image number 2
Hyper 212 Halo SF6 Ryu image number 3
Intuitive ARGB Detection
White Coated Heat Pipes
Wide Range Compatibility
Upgraded Installation Brackets
Street Fighter Top Cover
Clean White Finish
©CAPCOM CO., LTD. ALL RIGHTS RESERVED.
U.S. Shipping:
Ships from California
Price reduced from $49.99 to $29.99
Intuitive LED detection automatically provides default ARGB spectrum lighting or full ARGB customization via 3-pin header connection.
A polished top cover showing the exclusive collaboration with Street Fighter 6.
Upgraded
Redesigned brackets simplify installation on the latest available platforms
Wide Range
Compatibility
Compact 154mm height designed for wide chassis compatibility without sacrificing performance
  • Product Number RR-S4WW-20PA-RY
  • Exterior Color White
  • Dimensions (L x W x H) 124 x 73 x 154 mm / 4.8 x 2.8 x 6.0 inch
  • Heat Sink Material 4 Heat Pipes / Aluminum Fins
  • Fan Quantity 1 PC
  • Fan Speed 650-2050 RPM ± 10%
  • Fan Airflow 51.88 CFM (Max)
  • Fan Pressure 2.89 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Noise Level 27 dBA (Max)
  • Fan Rated Current 0.28A
  • Fan Safety Current 0.54A
  • Fan Power Consumption 3.36W
  • Cooler Type Air Cooler
  • Series Hyper
  • Heatpipes 4
