ERGO L image number 0
ERGO L image number 1
ERGO L image number 2
ERGO L image number 3
ERGO L image number 4
ERGO L image number 5
ERGO L image number 6
ERGO L image number 7
ERGO L image number 8
ERGO L image number 9
ERGO L image number 10
ERGO L image number 11
ERGO L image number 12
ERGO L image number 13
ERGO L image number 14
ERGO L image number 15
ERGO L image number 16
ERGO L image number 17
ERGO L image number 18
ERGO L image number 19
ERGO L image number 20
ERGO L image number 21
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
ERGO L
It's Got Your Back
ERGO L
Experience comfort and support on a whole new level with the Ergo L. Designed to help you stay more focused whether you're gaming or working with fully customizable support options for you to stay posture perfect.
U.S. Shipping:
Ships from California
Price reduced from $399.99 to $349.99
Work & Play Never Stops
Say yes to a chair that can take on any number of hours in front of your screen, be it for productivity or gaming. Build for utmost comfort, our Cooler Master Ergo Chair bridges the gap between performance looks and seated well-being for the champions that give their all every day. Better cooling and improved ventilation for longer sessions is provided by the breathable MuscleFlex® high tension mesh that also creates a unique suspended seating comfort with less fatigue and pressure. Get ready for work & play’s next level!
Designed for Comfort and Cooling Performance
Cast Aluminium Strength
Ergo L sports a 3D-engineered Cast Aluminium frame that synchronizes armrest with seatback reclining in a unibody design. This lightweight material doesn’t just look pristine but offers hours on hours of consistent performance and durability.
Hard Frame, Soft Core
The Ergo mesh seat and backrest undergo rigorous testing with over 20.000 cycles of abrasion, load and tensile tests. It’s rigid yet soft, subtle but powerful, the perfect companion for those who desires to be at the top of their game.
Effortless Personalization
Mesh Me Up!
Mesh Me Up!
Breathable MuscleFlex® high tension mesh is a ballistic-like material that strikes the perfect balance between strength and elasticity whilst providing uncompromised tenderness for all body shapes and weights! Tested at 100,000 cycles against impact and Technical Bulletin 117-2013 Smolder Resistance, the Cooler Master Ergo L can take a serious beating and still come out victorious. Like player, like chair.
  • Product Number CMI-GCEL-2019
  • Color Black
  • Total Height Range 120-134 cm / 47.2"-52.8"
  • Back Height 72-77.5cm / 28.3"-30.5" (headrest included)
  • Backrest Width 40-50 cm / 15.7"-19.7"
  • Armrest to Armrest 69 cm / 27.2"
  • Seating Area 51cm / 20.1"
  • Seat Width (including sides) 51 cm / 20.1"
  • Seat Depth 45-49 cm / 17.7"-19.3" (adjustable)
  • Diameter of Base 70 cm / 27.6"
  • Armrest Adjustability 24-28 cm / 9.4"-11.0"
  • Floor to Seat Top 48-56.5 cm / 18.9"-22.2"
  • Height Adjustability 8.5 cm / 3.3"
  • Seat Depth Adjustability 4cm / 1.6"
  • Recline 90-120 degree
  • Armrest 2D (lift, forward)
  • Headrest Adjustable (lift, tilt)
  • Inner Material High tension mesh
  • Frame Material Aluminum
  • Base Material Aluminum
  • Caster 75 mm / 3.0"
  • Gas Lift Class 4
  • Net Weight 27.8 kg / 61.3 lbs
  • Gross Weight 33.4 kg / 73.6 lbs
  • Max. Weight Load 200 kg / 440 lbs
  • Product Gaming Chair
  • Chair Type Ergonomic Series
