Elite Gold 1200 White Edition (All-Japanese Capacitors) image number 0
Elite Gold 1200 White Edition (All-Japanese Capacitors) image number 1
Elite Gold 1200 White Edition (All-Japanese Capacitors) image number 2
Elite Gold 1200 White Edition (All-Japanese Capacitors) image number 3
•Supports ATX 3.1 and PCIe Gen 5.1 standards
•Ideal for RTX 50 GPUs
•Stable performance under high loads at up to 40°C
•Quiet, long-life Rifle Bearing Fan cooling
•1200W output with 80 Plus Gold-certified efficiency
•Fully modular embossed cable design
•Reliable 10-year warranty
U.S. Shipping:
Ships from California
HIGH-POWER GOLD PERFORMANCE FOR GAMING AND WORKSTATIONS
Cooler Master Elite Gold 1200 White Edition (All-Japanese Capacitors) powers high-end gaming rigs and professional systems with ATX 3.1 support - ideal for RTX 50 GPUs. It offers 80 Plus Gold efficiency, reliable operation up to 50°C, quiet rifle bearing cooling, embossed modular cables, and a 10-year warranty for dependable, high-load performance.
High Temperature Resilience
Operates reliably at up to 50°C, making it ideal for extended gaming sessions, professional rendering, and sustained high-load workloads—all without sacrificing stability or efficiency.
Compatible with ATX 3.1 and PCIe Gen 5.1 standards
ATX 3.1 provides tighter voltage and current regulation, supporting up to 200% peak power. The Elite Gold 1200 White Edition meets full ATX 3.1 specs and supports PCIe Gen 5.1 for stable next-gen performance with RTX 50 GPUs and future high-power cards.
RIFLE BEARING FAN
RIFLE BEARING FAN
Cooler Master Elite Gold 1200 White Edition achieves over 90% efficiency at typical loads, reducing energy waste and heat output.
The fully modular design comes with flat white cables that can be tailored to each build, offering improved grip and a premium look for easier management and a cleaner overall setup.
  • Product Name Elite Gold 1200 White Edition (All-Japanese Capacitors)
  • Model MPX-C005-AFAG
  • Input Current 8 ~ 15A
  • Fan Size 135mm
  • Fan Bearing Rifle bearing
  • 80 PLUS Rating 80 PLUS Gold
  • Regulatory cTUV us, CB, CE, FCC, BSMI, EAC, RCM, UKCA, RoHS2.0 , REACH
  • ATX 24 Pin Connectors x1 = 1 (650mm)
  • EPS 4+4 Pin Connectors x1=1(600mm)
  • SATA Connectors x8 = 2 (450(s)mm+120(s)mm+120(s)mm+120(s)mm)
  • Peripheral Connectors x4=1(450(p)mm+120(p)mm+120(p)mm+120(p)mm)
  • PCI-e 6+2 Pin Connectors x3 = 3 (650mm)
  • 12+4 Pin Connectors x1 = 1 (650mm)
  • CPU 8 Pin x1=1(600mm)
  • Watts 1200W
  • 80 Plus Efficiency Gold
  • Warranty 10 Years
