Elite 450 image number 0
Elite 450 image number 1
Elite 450 image number 2
Elite 450 image number 3
Elite 450 image number 4
Elite 450 image number 5
Elite 450 image number 6
Elite 450 image number 7
Elite 450 image number 8
Elite 450 image number 9
Elite 450
Elite 450
Elite 450
Elite 450
Elite 450
Elite 450
Elite 450
Elite 450
Elite 450
Elite 450
Compact by Design. Airflow at the Core.
Elite 450
• Efficient Cooling Fan Configuration
• Short Airflow Path Design
• Ultra-Compact Sub-30L Volume
• Pure Air-Cooling Architecture
U.S. Shipping:
Ships from California
COMPACT BY DESIGN. AIRFLOW AT THE CORE.
The Elite 450 is a compact Micro-ATX case designed for modern desktop systems that demand efficient cooling without taking up unnecessary space.
Built around a dedicated air-cooling architecture, its optimized short airflow path helps deliver cool air directly toward heat-generating components. Two large 160mm ARGB fans at the front and a 120mm ARGB fan at the rear provide abundant airflow straight out of the box while adding customizable ambient lighting.
With a chassis volume under 30 liters, the Elite 450 balances a compact footprint with practical hardware support, accommodating Micro-ATX and Mini-ITX motherboards, graphics cards up to 317mm, and CPU coolers up to 163mm.
EFFICIENT COOLING FAN CONFIGURATION
Big Fans. Bigger Airflow.
Dual 160mm ARGB front fans and a 120mm ARGB rear fan deliver powerful airflow with vibrant lighting right out of the box.
SHORT AIRFLOW PATH DESIGN
Cooler Air. Faster.
A shortened airflow path directs fresh air quickly to key components, helping reduce heat buildup and improve cooling efficiency.
ULTRA-COMPACT SUB-30L VOLUME
Compact Without Compromise.
A sub-30L footprint saves valuable desk space while supporting capable Micro-ATX and Mini-ITX builds.
PURE AIR-COOLING ARCHITECTURE
Built to Breathe.
Purpose-built for air cooling, the Elite 450 optimizes internal airflow for simple, efficient, and reliable thermal performance.
MESH FRONT PANEL
Maximum Airflow Up Front.
The high-airflow mesh front lets the dual 160mm fans breathe freely, feeding fresh air directly into your system.
TEMPERED GLASS SIDE PANEL
Put Your Build on Display.
A tempered glass side panel gives you a clear view of your hardware and ARGB lighting.
MODERN FRONT I/O
Connected. Convenient.
Easy-access USB Type-A, USB Type-C, and dedicated audio connections keep everyday connectivity within reach.
  • Product Name Elite 450
  • Model Number E450-KGNN-S00
  • Color Black
  • Material - Front Panel Mesh
  • Material - Left Side Panel Tempered Glass
  • Material - Right Side Panel Steel
  • Dimensions (L x W x H) - Incl. Protrusions 392mm×208mm×396mm
  • Dimensions (L x W x H) - Excl. Protrusions 358mm×208mm×382mm
  • Motherboard Support Micro-ATX / ITX
  • Expansion Slots 4
  • Drive Bays - 5.25’’ ODD N/A
  • Drive Bays - 3.5’’ HDD 1
  • Drive Bays - 2.5’’ SSD 2
  • I/O Panel - USB Ports USB 3.2 Gen1 Type A*1 + USB 3.2 Gen1 Type C*1 + USB1.0*1
  • I/O Panel - Audio In 1 x 3.5mm
  • I/O Panel - Audio Out 1 x 3.5mm
  • Fan Support - Top 2 x 120mm or 2 x 140mm
  • Fan Support - Front 2 x 160mm
  • Fan Support - Bottom 2 x 120mm
  • Pre-installed Fans - Rear 1*120mm ARGB
  • Pre-installed Fans - Front 2*160mm ARGB
  • Radiator Support - Top N/A
  • Radiator Support - Side N/A
  • Clearances - CPU Cooler 163mm
  • Clearances - Power Supply 160mm
  • Clearances - Graphics Card 317mm
  • Power Supply Support ATX
  • Warranty 2 Years
