COSMOS ALPHA image number 0
COSMOS ALPHA image number 1
COSMOS ALPHA image number 2
COSMOS ALPHA image number 3
COSMOS ALPHA image number 4
COSMOS ALPHA
COSMOS ALPHA
COSMOS ALPHA
COSMOS ALPHA
COSMOS ALPHA
Build Without Limits
COSMOS ALPHA
COSMOS series, hailed as the ultimate expression of PC case modularity, evolves into the “halo” platform for enthusiasts and modders. With its iconic design language and enhanced modular internals, COSMOS is engineered for boundary-pushers who want limitless control over layout, cooling, and customization.
Brand new COSMOS ALPHA will serve as the aspirational apex of what FreeForm 2.0 stands for — freedom, scale, and personalization without compromise, making it an ALPHA case for all ALPHA builders
  • In Stock
U.S. Shipping:
Ships from California
$499.99
COSMOS ALWAYS LEADING
Sliding Motherboard Tray
Sliding tray design to free up the space inside the case and enable seamless system reconfiguration between air and liquid cooling layouts. Builders can also fine-tune the distance between GPU and side panels with ease – whether to optimize airflow or highlight GPU upfront
Sliding Adjustable Fan Bracket
Adjustable to accommodate case fans in different sizes, and the sliding design allow users to easily move the fans closer to heat spots for better airflow to cool down the system.
Maximized Compatibility & Space
Support E-ATX/EEB motherboards, 400mm GPUs, and 240mm PSUs. Tool-free bays support up to 7 drives for effortless expansion. Provide builders with uncompromised platform for wide-open FreeForm creation.
  • Product Name COSMOS ALPHA
  • Series COSMOS Series
  • Color(s) Black / Silver
  • Model Number C700-KGNN-S00
  • Materials - Exterior SGCC / Plastic
  • Materials - Side Panel (Left / Right) Tempered Glass / Metal
  • Dimensions (L x W x H) 669 x 330 x 639 mm (Incl. Protrusions), 579 x 260 x 582 mm (Excl. Protrusions)
  • Volume 88 L (no panel / protrusions / feet)
  • Volume 140 L (with panel / protrusions / feet)
  • Motherboard Support Mini-ITX / Micro-ATX / ATX / E-ATX / EEB
  • Power Supply Support ATX
  • PCI Expansion Slots 8
  • Drive bay support - 5.25" Drive Bays 0
  • Drive bay support - 2.5" / 3.5" Drive Bays (or SSD) 2 or 2 (CPU Cooler under 165 mm)
  • Preinstalled Drive Bays - 5.25" Drive Bay 0
  • Preinstalled Drive Bays - 2.5" / 3.5" Drive Bays (or SSD) 2 or 2 (CPU Cooler under 165 mm)
  • I/O Panel - USB Ports 4x USB 3.2 Gen 1 Type-A 5G, 2x USB 3.2 Gen 2x2 Type-C 20G
  • Preinstalled Fan (Fan dim./ Fan speed/ LED color/ Fan Connector ) - Front 2x 200x38 mm (Non-ARGB)
  • Preinstalled Fan (Fan dim./ Fan speed/ LED color/ Fan Connector ) - Rear 1x Mobius 120x25 mm (Non-ARGB)
  • Fan Support - Front 3x 120mm / 3x 140mm /  2x 200mm
  • Fan Support - Top 3x 120mm / 2x 140mm /  2x 180mm / 2x 200mm
  • Fan Support - Rear 3x 120mm
  • Fan Support - Bottom 3x 120mm / 2x 140mm /  2x 180mm / 2x 200mm
  • Fan Support - Side Mount 3x 120mm / 3x 140mm /  2x 180mm / 2x 200mm
  • Radiator Support - Top 120 / 140 / 240 / 280 / 360 mm (maximum thickness clearance 93mm)
  • Radiator Support - Bottom 120 / 140 / 240 / 280 / 360 mm (maximum thickness clearance 93mm)
  • Radiator Support - Side Mount 120 / 140 / 240 / 280 / 360 / 420 / 3x360 mm (maximum thickness clearance 80mm)
  • Dust Filters Yes, Removable Filters
  • Clearances - CPU Cooler 186 mm
  • Clearances - Power Supply 240 mm
  • Clearances - Graphics Card 400 mm
  • Cable Routing - Behind Motherboard Tray 53 mm
  • Included Accessories VGA card holder
  • Included Accessories Decorative cover
  • Included Accessories Right side cable cover
  • Size Full Tower
