Caliber X1 image number 0
Caliber X1 image number 1
Caliber X1 image number 2
Caliber X1 image number 3
Caliber X1 image number 4
Caliber X1 image number 5
Caliber X1
Caliber X1
Caliber X1
Caliber X1
Caliber X1
Caliber X1
Caliber X1
The Caliber X1 is designed for ultra comfort and style that provides ergonomic relief for those long gaming sessions.
U.S. Shipping:
Ships from California
Price reduced from $399.99 to $99.99
  • Product Number CMI-GCX1-2019
  • Color Black
  • Total Height Range 130-138 cm / 51.2"-54.3"
  • Backrest Length 86cm / 33.9"
  • Backrest Width 58 cm / 22.8"
  • Armrest to Armrest 72 cm / 28.3"
  • Seat Width (including sides) 54 cm / 21.3"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 70 cm / 27.6"
  • Metal Plate Thickness 1.5 mm
  • Armrest Adjustability 30-37 cm / 11.8"-14.6"
  • Floor to Seat Top 50-58 cm / 19.7"-22.8"
  • Height Adjustability 8 cm / 3.1"
  • Armrest Width Adjustability 1.5 cm / 0.6"
  • Recline 90-180 degree
  • Armrest 4D (lift, sway, swivel, forward)
  • Headrest Ergonomic Pillow
  • Extra Padded Backrest Built-in pillow (hidden stripes)
  • Inner Material Molded Foam
  • Frame Material Steel
  • Base (leg) Aluminum
  • Caster 75 mm / 3.0"
  • Gas Lift Class 4
  • Net Weight 24.7 kg / 54.5 lbs
  • Gross Weight 29.0 kg / 63.9 lbs
  • Max. Weight Load 150 kg / 330 lbs
  • Product Gaming Chair
  • Chair Type Caliber X1 Series
