Caliber R2 Gaming Chair image number 0
Caliber R2 Gaming Chair image number 1
Caliber R2 Gaming Chair image number 2
Caliber R2 Gaming Chair image number 3
Caliber R2 Gaming Chair image number 4
Caliber R2 Gaming Chair image number 5
Caliber R2 Gaming Chair image number 6
Caliber R2 Gaming Chair image number 7
Caliber R2 Gaming Chair image number 8
Caliber R2 Gaming Chair image number 9
Caliber R2 Gaming Chair image number 10
Caliber R2 Gaming Chair image number 11
Caliber R2 Gaming Chair image number 12
Caliber R2 Gaming Chair image number 13
Caliber R2 Gaming Chair image number 14
Caliber R2 Gaming Chair image number 15
Caliber R2 Gaming Chair image number 16
Caliber R2 Gaming Chair image number 17
Caliber R2 Gaming Chair image number 18
Caliber R2 Gaming Chair image number 19
Caliber R2 Gaming Chair image number 20
Caliber R2 Gaming Chair image number 21
Caliber R2 Gaming Chair image number 22
Caliber R2 Gaming Chair image number 23
Caliber R2 Gaming Chair image number 24
Caliber R2 Gaming Chair image number 25
Caliber R2 Gaming Chair image number 26
Caliber R2 Gaming Chair image number 27
Caliber R2 Gaming Chair image number 28
Caliber R2 Gaming Chair image number 29
Caliber R2 Gaming Chair image number 30
Caliber R2 Gaming Chair image number 31
Caliber R2 Gaming Chair image number 32
Caliber R2 Gaming Chair image number 33
Caliber R2 Gaming Chair image number 34
Take Over the Competition
Cooler Master Caliber R2 is designed for upgraded comfort and style with Caliber R1 design language in mind that enhances your game.
U.S. Shipping:
Ships from California
Price reduced from $279.99 to $89.99
  • Diameter of Base 70 cm / 27.6"
  • Seat Width (including sides) 58 cm / 22.8"
  • Caster 60 mm / 2.4"
  • Net Weight 21.5 kg / 47.4 lbs
  • Color Black
  • Product Gaming Chair
  • Backrest Height 82 cm / 32.3"
  • Steel Plate Thickness 1.2 mm
  • Total Height Range 125.5-133.5 cm / 49.4"-52.6"
  • Seating Area 38cm / 15.0"
  • Color Purple
  • Floor to Seat Top 48-56 cm / 18.9"-22.0"
  • Frame Material Steel
  • Gas Lift Class 4
  • Max. Weight Load 150 kg / 330 lbs
  • Height Adjustability 8 cm / 3.1"
  • Recline 90-180 degree
  • Backrest Width 58 cm / 22.8"
  • Seat Depth 54 cm / 21.3"
  • Headrest Ergonomic Pillow
  • Inner Material Backrest: cut foam
  • Armrest to Armrest 71 cm / 28.0"
  • Chair Type Caliber R2 Series
  • Base (leg) Steel
  • Armrest 2D
  • Armrest Adjustability 28.5-36.5 cm / 11.2"-14.4"
  • Product Number CMI-GCR2-2019
  • Inner Material Seatbase: cold molded foam
  • Color Red
  • Gross Weight 25.6 kg / 56.4 lbs
  • Color Gray
  • Color KANA
