Atlas ARGB GPU Support image number 0
Atlas ARGB GPU Support image number 1
Atlas ARGB GPU Support image number 2
Atlas ARGB GPU Support image number 3
Atlas ARGB GPU Support image number 4
Atlas ARGB GPU Support image number 5
Atlas ARGB GPU Support image number 6
Elevate Into Next Dimension
Introducing Cooler Master's Atlas ARGB GPU Support Bracket featuring an infinity mirror design, edge-lit ARGB tempered glass, an aluminum stand, tool-free installation, no GPU sag and a versatile support.
U.S. Shipping:
Ships from California
Price reduced from $49.99 to $19.99
Edge-lit ARGB Tempered Glass
ARGB lighting rails have been added via CNC machining on the tempered glass, bolstered by enhanced lighting thanks to extra ARGB bulbs. The edge-lit, transparent design provides an aesthetic accent without blocking your card. Alternatively, turn off the lights for a near invisible aesthetic.
Eliminated GPU Sag
As GPUs like the 40 series become larger, PCIe slots may suffer increased stress. The Atlas eliminates this by supporting the GPU's weight at critical points throughout the length of the card.
Our strength testing shows that the Atlas can support the heaviest of cards without even flinching.
Premium Materials
Aluminum Stand
A fully aluminum stand provides strengthened and stylish support, built from premium materials specially designed to hold up even the heaviest GPUs.
  • Model Number MCA-U000R-AGSBTG-00
  • Color(s) Silver Gray
  • Materials Aluminium, Plastic, Tempered Glass, Magnet
  • Dimensions (L x W x H) Vertical - 51.8 x 59.6 x 195.7mm (with arm), Horizontal - 195.7 x 44.2 x 51.3mm~75.5mm (without arm)
  • Support Arm Force Max. 3kg
  • ARGB Cable length 600mm/23.6inch
  • Included Aluminum Support Arm 1
  • ARGB Controller Not Included
  • Net Weight 236g
  • Gross Weight 433g
  • Series Others
