HAF II 500 | V8 ACE 3DHP image number 0
HAF II 500 | V8 ACE 3DHP image number 1
HAF II 500 | V8 ACE 3DHP image number 2
HAF II 500 | V8 ACE 3DHP image number 3
Cooler, Quieter, Stronger
Industry-Leading Noise-Normalized Cooling Performance​
More Balanced Intake–Exhaust Architecture​
Split-Level Layout for Enhanced Airflow​
MasterRail Multi-Purpose Mounting System​
Supports Versatile GPU configurations
CPU
U.S. Shipping:
Ships from California
$289.99
INDUSTRY-LEADING NOISE NORMALIZED COOLING PERFORMANCE
HAF II 500 is engineered to deliver lower component temperatures without increasing system noise, redefining what an airflow case can achieve.
BALANCED AIRFLOW, NOT JUST BIGGER AIRFLOW
The Largest and Thickest Fans Ever Used in a Consumer PC Case
Two Mighty40 F220 intake fans and one Mighty40 V180 exhaust fan work together to create a balanced airflow system. By maximizing airflow at lower RPMs, HAF II 500 achieves exceptional cooling performance while keeping noise under control.
LOW AIRFLOW RESISTANCE DESIGN
Built to Let Air Move Freely
Large front and rear ventilation openings increase airflow throughout while minimizing chassis-induced interference, allowing the cooling system to perform closer to its full potential.
THE ARCHITECTURE BEHIND THE PERFORMANCE
Split-Level Cable Management
The Split-Level Layout reallocates cable-routing space based on actual routing needs, creating room for the oversized 180 mm exhaust fan while maintaining controlled chassis dimensions and improving overall cooling efficiency.
MASTERRAIL MULTI-PURPOSE MOUNTING SYSTEM
MasterRail combines adjustable sliding rails with a standardized mounting platform that supports multiple fan and radiator sizes while maintaining an unobstructed airflow path.
Beyond fans and radiators
MasterRail is designed to support future accessories and compatible third-party devices that share common mounting patterns, extending flexibility far beyond traditional mounting systems.
SLIDING CABLE COVER
The sliding cable cover conceals cables within the centralized routing chamber and visually blends with the motherboard area.
Its airflow-guiding design reduces airflow interference, while shark-gill-inspired vents assist memory cooling.
DUAL-MODE GPU HOLDER
The Dual-Mode GPU Holder lets users clamp a single graphics card for improved transport stability or support two graphics cards up to 3.6 slots / 72 mm thick each.
THERMALLY PRIORITIZED AIRFLOW DIVIDER
The airflow divider directs airflow from the lower intake fan toward the GPU, the most thermally demanding component in a typical system, while maintaining effective cooling for storage drives and nearby PCIe devices.
WORKSTATION COMPATIBILITY
Built Beyond Gaming
Support for up to four dual-slot GPUs or two 72 mm-thick graphics cards enables powerful workstation configurations for AI, rendering, simulation, and other GPU-compute-intensive workloads.
FLEXIBLE COOLING COMPATIBILITY
With support for multiple fan and radiator configurations across the top, front, and rear panels, HAF II 500 gives builders the flexibility to create high-airflow or liquid-cooled systems.
OPTIMIZED CABLE ROUTING EXPERIENCE
Zoned cable-routing space, integrated cable straps, and a centralized routing chamber streamline the building experience, helping keep builds organized while simplifying cable management and preserving airflow efficiency throughout the chassis.
Product Specifications
  • Product Name HAF II 500
  • Dimension (L x W x H) Incl. Protrusions 557 x 262 x 548 mm
  • Dimension (L x W x H) Volume (Incl. Protrusions) 79.98 L
  • Motherboard Support Mini-ITX, Mini-DTX, Micro-ATX, ATX, CEB (ATX-Compatible Standoff Pattern), E-ATX (ATX-Compatible Standoff Pattern; Up to 310 mm Wide)
  • Material - Chassis SGCC (0.7 – 0.8 mm Thickness)
  • Material - Panel ABS
  • Material - Side Panel Tempered Glass (Left Panel); SGCC (Right Panel)
  • Clearance - Cable Routing 15 – 40 mm
  • Clearance - CPU Cooler 221 mm (Intel); 220 mm (AMD)
  • Clearance - Power Supply 150 mm (North-South Drive Orientation); 210 mm (East-West Drive Orientation)
  • Clearance - Graphics Card Length 430 mm (With Mighty40 F220 Fans Installed)
  • Clearance - Graphics Card Thickness 72 mm / Card When Installing 2 Graphics Cards; 40 mm / Card When Installing 4 Graphics Cards
  • Dust Filters Top / Front / Bottom (PSU)
  • Expansion Slots 8
  • Drive Bay Support - 3.5” / 2.5” 3 / 6 (PSU Length ≤ 150 mm) ; 2 / 4 (150 mm < PSU Length ≤ 210 mm)
  • Preinstalled Drive Bay - 3.5” / 2.5” 3 / 6
  • Fans Support Top 3 x 120 / 140 mm, or 2 x 160 / 180 mm
  • Fans Support Front Default: 2 x 220 mm; With MasterRails: 3 x 120 / 140 mm, or 2 x 160 / 180 mm
  • Fans Support Rear 1 x 180 mm
  • Pre -installed Fans Front 2 x Mighty40 F220
  • Pre -installed Fans Rear 1 x Mighty40 V180
  • Fan Hub Ports 6 x PWM; 6 x ARGB
  • Fan Hub Total Power Capacity 54W
  • Radiator Support Top 240 / 280 / 360-120 / 360-180 mm (Conditional Support*)
  • Radiator Support Front With MasterRails: 240 / 280 / 360-120 / 360-180 mm (Conditional Support**)
  • I/O Panel Power LED 1
  • I/O Panel USB Ports 1 x USB 3.2 Gen 2x2 Type-C; 2 x USB 3.2 Gen 1 Type-A
  • I/O Panel Audio in / out 1 x 3.5 mm Headset Jack (Audio + Mic)
  • I/O Panel Reset Switch 1
  • Warranty Case 2 Years
  • Warranty Fan 5 Years
Fan Specifications - Mighty40 F220
  • Product Name Mighty40 F220
  • Dimension (L x W x H) 220 x 220 x 40 mm
  • Rated Voltage 12 V DC
  • Max Current 0.5 A
  • Speed 200 – 1050 rpm
  • Max Airflow 203.8 CFM
  • Max Pressure 3.1 mmH2O
  • Max Noise (at 1 m) 36 dB(A)
  • Bearing Type Dual Ball Bearing
  • Frame Material PBT
  • Blade Material LCP
  • Weight 500 g
  • Warranty 5 years
Fan Specifications - Mighty40 V180
  • Product Name Mighty40 V180
  • Dimension (L x W x H) 180 x 180 x 40 mm
  • Max Current 0.3 A
  • Speed 250 – 1370 rpm
  • Max Airflow 161.5 CFM
  • Max Pressure 4.0 mmH2O
  • Max Noise (at 1 m) 34 dB(A)
  • Weight 425 g
  • Warranty 5 years
