X Mighty 2000 image number 0
X Mighty 2000 image number 1
X Mighty 2000 image number 2
X Mighty 2000 image number 3
X Mighty 2000
X Mighty 2000
X Mighty 2000
X Mighty 2000
UNLEASH NEXT-GEN MIGHT
X Mighty 2000
• Advanced aluminum thermal structure
• 80 Plus Platinum efficiency certification
• ATX 3.1 support & two durable 12V-2x6 cables
• GeForce RTX 50 Series Ready
• Digital Power Management System
• 10-year warranty
Unleash Next-Gen Might
The X Mighty Platinum is a powerhouse blending high-capacity performance, top-tier industrial-grade IC components, and sophisticated interleaved PFC topology. This PSU is engineered to meet the demanding needs of server and artificial intelligence industries, featuring dual 12V-2x6 connectors designed for rigorous, high-performance applications.
AI-Ready Dual GPU Support with Color-Coded Precision
Supports dual 12V-2x6 connectors for dual GPU configurations, ideal for AI and machine learning workloads. Features dual-color connects (black and purple) to ensure correct installation.
Infineon Industrial-Grade Chipset for Enduring Reliability
Infineon industrial-grade chipset ensures long-lasting reliability
Active Bridge Rectifier for Boosted Efficiency and Stability
Active bridge rectifier for enhanced power efficiency and stability
Advanced Aluminum Design for Superior Cooling and Durability
Advanced aluminum thermal structure ensures excellent heat dissipation and durability
Premium Japanese Capacitors for Silent, Long-Lasting Performance
High-quality Japanese capacitors improve longevity and reduce electrical noise
PMBus Support for Enterprise-Grade Performance Monitors
PMBus port support offers enterprise-grade performance monitoring capability
  • Model MPS-K001-AFBP
  • Input Voltage 115 - 240V (115 - 240V for 1600W / 200 - 240V for 2000W)
  • Input Current 16A (Max)
  • Fan Bearing FDB
  • Fan Speed 2500 RPM
  • Efficiency ≥ 94% @ Typical Load
  • 80 PLUS Rating 80 PLUS Platinum of EU Internal
  • Hold Up Time ≥ 16ms
  • Regulatory cUL, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA/BIS, KC (based on region's request.)
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 4
  • 12V-2x6 Connectors 2
  • USB 10P Connector 1
  • PMBus 5 Pin Connector 1
  • Series X Series
  • 80 Plus Efficiency Platinum
  • Category Above 750W
  • Watts 2000W
