V8 Ver.2 (EU only) image number 0
V8 Ver.2 (EU only) image number 1
V8 Ver.2 (EU only) image number 2
V8 Ver.2 (EU only) image number 3
V8 Ver.2 (EU only)
V8 Ver.2 (EU only)
V8 Ver.2 (EU only)
V8 Ver.2 (EU only)
V8 Ver.2 (EU only)
V8 Ver.2 (EU only)
  • Heat Pipe Dimensions Ø6mm
  • Cooler Type Air Cooler
  • Rated Voltage 12 VDC
  • Legacy Cooling
  • Connector 4-Pin
  • Fan Life Expectancy 160,000 Hours
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Bearing Type POM Bearing – Cooler Master 4th Gen. Bearing (*POM = Polyoxymethylene)
  • Heat Sink Material Vapor Chamber
  • Heat Sink Material 8 Heat Pipes
  • Fan Speed 600-1600 RPM ± 10%
  • CPU Socket LGA1366
  • Rated Current 0.31A
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • Fan Weight 110g / 0.24lb
  • Fan Dimensions (L x W x H) 140 x 140 x 20 mm / 5.5 x 5.5 x 0.8 inch
  • CPU Socket AM3+
  • CPU Socket AM3
  • Fan Airflow 28 – 82 CFM ± 10%
  • CPU Socket AM2
  • CPU Socket FM2+
  • Heat Sink Dimensions (L x W x H) 154 x 140 x 153.5 mm / 6.1 x 5.5 x 6.0 inch
  • CPU Socket FM2
  • CPU Socket FM1
  • Power Consumption 3.72W
  • Heat Sink Weight 854g / 1.9lb
  • Fan Noise Level 16 - 36 dBA
  • Fan Air Pressure 0.3 - 1.45 mmH2O ± 10%
  • Dimensions (L x W x H) 154 x 149.8 x 166.5mm / 6.1 x 5.9 x 6.6 inch
  • EAN code 4719512048368
  • UPC code 884102027321
  • Product Number RR-V8VC-16PR-R2
