Cooler Master V-Series
V8 ACE 3DHP
Product Overview
Built to push single-tower cooling further.
V8 ACE 3DHP is Cooler Master’s flagship single-tower air cooler, built around 3DHP heatpipe technology, pressure-focused airflow, and platform-specific CPU contact.
The 3DHP thermal path is designed to help move heat from the CPU hotspot into more of the fin stack.
Dual 120 × 30 mm PWM fans drive air through the dense fins, while LCP blades and Loop Dynamic Bearings support stable airflow for long gaming, rendering, and workstation loads.
Engineered from base to airflow.
3DHP Heat Path
Routes hotspot heat upward into the fin stack.
Hybrid Heatpipes
Combines focused pickup with wide heat spreading.
Dense Fin Stack
Expands heat-exchange surface area in a single tower.
Front Pressure Fan
Drives pressure through the dense fin stack.
Rear Exhaust Fan
Pulls heated air out for cleaner exhaust flow.
LCP Blades
Helps reduce blade flex at higher RPM.
Platform-Tuned Mounting
Dedicated AMD and Intel mounting helps match socket geometry, contact pressure, and thermal-load behavior.
Sliding Side Fans
Slides out for easier RAM access and service.
Engine-Inspired Top
A clean, mechanical look built around performance.
Independent Validation
Independently tested by Cybenetics and validated as a top-performing air cooler in its class.
#1 single-tower air cooler and #2 air cooler overall in the tested Cybenetics data set.
Cybenetics-Tested Performance
Cybenetics-validated cooling.
Cybenetics testing validates the V8 ACE 3DHP balance of cooling performance, heat control, and fan noise.
Validated as the top single-tower air cooler in the tested Cybenetics data set.
Ranked near the very top of all tested air coolers, including larger cooler designs.
Designed to help the CPU stay boosted during heavy workloads instead of dropping speed from heat.
Performance is validated across cooling strength, heat control, and full-fan noise.
3DHP Innovation
3DHP heat routing.
3DHP helps route heat from the CPU hotspot into the fin stack, helping more of the heatsink participate in heat exchange.
Hybrid Heatpipe Architecture
Hybrid heatpipe layout.
Two 3DHP pipes focus on hotspot transfer, while four heatpipes spread thermal load across the aluminum fin stack.
Heat pickup → heat spread → heat exchange
Heat is pulled from the CPU base, spread through the fin stack, then carried away by airflow.
Full-Stack Fin Activation
Full-stack fin activation.
By routing heat deeper into the fin stack, V8 ACE 3DHP helps activate more surface area under sustained load.
Pressure-Tuned Push-Pull Airflow
Pressure-tuned airflow.
Dual 120 × 30 mm PWM fans push and pull air through the dense fin stack to help move heat out of the cooler.
LCP Blade Stability
Stable blades. Strong airflow.
Liquid Crystal Polymer fan blades help reduce flex at higher RPM, keeping airflow more stable through the fin stack.
Made for Your Platform
Platform-tuned contact.
Intel and AMD CPUs use different socket layouts, IHS shapes, and hotspot behavior. V8 ACE 3DHP uses dedicated mounting hardware to help control pressure, alignment, and heat transfer at the CPU contact point.
Compact Footprint
Flagship single-tower fit.
At 138.95 × 136.47 × 167.3 mm, V8 ACE 3DHP is designed to deliver flagship cooling in a cleaner single-tower form factor.
Controlled Acoustic Performance
Cooling without the noise spike.
The front fan is rated up to 37 dB(A), while the rear fan is rated up to 34 dB(A). This helps balance strong airflow with controlled acoustics during demanding workloads.
Choose your platform.
V8 ACE 3DHP is available in dedicated AMD and Intel versions with platform-specific socket support and mounting hardware.
AMD Version
| Spec | Value |
| Platform Version | V8 ACE 3DHP AMD |
| Socket Support | AMD® AM5 / AM4 |
| Dimensions | 138.95 × 136.47 × 167.3 mm |
| Heat Sink Material | 2 × 3DHP / 4 × HP / Aluminum Fins |
| Front Fan | 120 × 120 × 30 mm, 0–2500 ±250 RPM, 89.6 CFM, 3.85 mmH₂O, 37 dB(A) |
| Rear Fan | 120 × 120 × 30 mm, 0–2050 ±250 RPM, 61.0 CFM, 2.0 mmH₂O, 34 dB(A) |
| Bearing / MTTF | Loop Dynamic Bearing / >200,000 hours |
| Warranty | 6 years |
Intel Version
| Spec | Value |
| Platform Version | V8 ACE 3DHP Intel |
| Socket Support | Intel® LGA 1851 / 1700 / 1200 / 1151 / 1150 / 1155 / 1156 |
