MWE Bronze 650 V3 230V image number 0
 MWE Bronze 650 V3 230V image number 1
 MWE Bronze 650 V3 230V image number 2
 MWE Bronze 650 V3 230V image number 3
 MWE Bronze 650 V3 230V image number 4
 MWE Bronze 650 V3 230V image number 5
 MWE Bronze 650 V3 230V image number 6
 MWE Bronze 650 V3 230V image number 7
Power Evolved
ATX 3.1 support
High temperature resilience
Quiet HDB fan
80 Plus Bronze certified efficiency
Embossed cable
5-year warranty
Buy Now
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, this unit is ideal for use with the 40 series GPUs.
Embossed Cable
Quiet HDB Fan
Certified Efficiency
The MWE Bronze V3 230V is certified to achieve more than 88% efficiency at typical loads.​​​​
High Temperature Resilience
  • Model MPE-6501-ACABW-3B
  • Input Voltage 200-240V
  • Input Current 5A
  • Fan Bearing HDB
  • Efficiency >88% @ Typical Load
  • 80 PLUS Rating 80 PLUS Bronze EU 230V
  • Hold Up Time >16ms
  • Regulatory TUV, CE, FCC, CCC, EAC, RCM, UKCA, RoHS2.0 / BIS, KC (based on region's request.)
  • SATA Connectors 6
  • PCI-e 6+2 Pin Connectors 4
  • Warranty 5 Years
  • Series MWE Bronze Series
  • Category 500 to 750W
  • Modular Non Modular
  • 80 Plus Efficiency Bronze
  • Watts 650W
