Mobius 120 OC image number 0
Mobius 120 OC image number 1
Mobius 120 OC
Mobius 120 OC
More Balance, More Burst
Mobius 120 OC
Ring Blade Design
Fan Speed Toggle
Metal Motor Hub
Double Ball Bearing
Lifetime Warranty
Premium Anti-Vibration Dampers
Buy Now
FAN SPEED TOGGLE
Integrated fan speeds toggle built into the cable let you conveniently adjust fan speeds from 1500rpm up to 3200rpm.
DOUBLE BALL BEARING
Double Ball Bearings reduces friction to a minimum for silence and extended lifespan.
PREMIUM
ANTI-VIBRATION DAMPERS
Patented corner mount design dampen vibration and rattling while maintaining chassis stability for silent operation.
METAL MOTOR HUB
Motor hub constructed of metal for additional stability and reinforcement for extended superior fan performance.
  • Product Number MFZ-M2NN-32NPK-R1
  • Fan Dimensions (L x W x H) 120 x 120 x 27 mm / 4.7 x 4.7 x 1 inch
  • Fan Profiles Non-LED
  • Fan Speed L: 1050-1500 ± 200 RPM, M: 1050-2400 ± 250 RPM, H: 1050-3200 ± 10% RPM
  • Fan Airflow L: 40.2 CFM, M: 65.5 CFM, H: 88.1 CFM
  • Fan Noise Level L: 17.4 dBA, M: 31.1 dBA, H: 39.3 dBA
  • Fan Bearing Type Two Ball Bearing
  • Fan Pressure L: 1.19 mmH₂O, M: 2.76 mmH₂O, H: 4.75 mmH₂O
  • Fan MTTF >200,000 Hours
  • Fan Connector 4-Pin PWM (with speed control line)
  • Fan Rated Current L: 0.10 A, M: 0.20 A, H: 0.35 A
  • Fan Safety Current 0.5A
  • Fan Power Consumption L: 1.20 W, M: 2.40 W, H: 4.20 W
  • Fan Weight 220g / 0.48 lbs
  • Cooler Type Case Fan
  • Series Mobius Series
