MasterBox 5 - Black with MeshFlow Front Panel (B2B) image number 0
MasterBox 5 - Black with MeshFlow Front Panel (B2B) image number 1
MasterBox 5 - Black with MeshFlow Front Panel (B2B) image number 2
MasterBox 5 - Black with MeshFlow Front Panel (B2B) image number 3
You Decide the Inside
  • Liquid Cooling Support - Rear 120mm
  • Pre-installed Fans 120mm x 1 (MCY-B5S1-KKNN-01)
  • Fan Support 3x 120mm / 2x 140mm (MCY-B5P2-KWGN-00)
  • Pre-installed Fans 1x 120mm (MCY-B5S1-KWYN-02)
  • I/O Panel 2x USB 3.0
  • Dust Filters Front
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Legacy Cases
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Liquid Cooling Support - Front 240mm
  • Pre-installed Fans 2x 120mm (MCY-B5S1-KWNN-03)
  • Pre-installed Fans 2x 120mm (MCY-B5S1-KWYN-04)
  • Liquid Cooling Support - Front 280mm
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Pre-installed Fans 3x 120mm (MCY-B5S1-KKYA60-05)
  • 2.5" / 3.5" Drive Bays (Combo) 2 (MCY-B5P2-KWGN-00)
  • Pre-installed Fans 1x 120mm (MCY-B5P2-KWGN-00)
  • Clearance - GFX 285mm/11.7" (w/3.5" HDD cage)
  • 2.5" / 3.5" Drive Bays (Combo) 2 (MCY-B5S1-KKNN-01)
  • Expansion Slots 7
  • Motherboard Support ATX
  • Liquid Cooling Support - Front 240mm (MCY-B5P2-KWGN-00)
  • 2.5" / 3.5" Drive Bays (Combo) 2 (MCY-B5S1-KWYN-02)
  • 2.5" / 3.5" Drive Bays (Combo) 2 (MCY-B5S1-KWNN-03)
  • Liquid Cooling Support - Front 280mm (MCY-B5P2-KWGN-00)
  • Liquid Cooling Support - Front 360mm (MCY-B5P2-KWGN-00)
  • 2.5" / 3.5" Drive Bays (Combo) 2 (MCY-B5S1-KWYN-04)
  • Cable Routing - Behind Motherboard Tray 25-35mm
  • Materials Steel body
  • Fan Support - Top 1x 140mm
  • Materials Plastic mesh bezel
  • Clearance - CPU Cooler 167mm/6.5"
  • Fan Support - Top 1x 120mm
  • 2.5" / 3.5" Drive Bays (Combo) Cages sold separately (MCY-B5S1-KKYA60-05)
  • Fan Support - Front 2x 120/140mm (MCY-B5S1-KKNN-01, MCY-B5S1-KWYN-02, MCY-B5S1-KWYN-04, MCY-B5S1-KKYA60-05)
  • Fan Support - Front 3x 120/140mm (MCY-B5S1-KWNN-03, MCY-B5S1-KWYN-04)
  • Power Supply Support Bottom Mount (MCY-B5S1-KKYA60-05)
  • Power Supply Support B2 600W (MCY-B5S1-KKYA60-05)
  • Clearance - GFX 410mm/16.1" (MCY-B5P2-KWGN-00)
  • Clearance - GFX 410mm/16.2" (w/o 3.5" HDD cage)
  • Dimensions (L x W x H) 500 x 220 x 475 mm
  • Clearance - GFX 410mm/16.2" (w/o 3.5" HDD cage) - MCY-B5P2-KWGN-00
  • 5.25" Drive Bays Cages sold separately (MCY-B5S1-KKNN-01)
  • 5.25" Drive Bays 2 (MCY-B5S1-KWYN-02)
  • 5.25" Drive Bays Cages sold separately (MCY-B5S1-KWNN-03)
  • 5.25" Drive Bays 2 (MCY-B5S1-KWYN-04)
  • 5.25" Drive Bays 2 (MCY-B5S1-KKYA60-05)
  • Materials Steel body (MCY-B5P2-KWGN-00)
  • Materials Plastic front cover (MCY-B5P2-KWGN-00)
  • Materials Tempered glass panel (MCY-B5P2-KWGN-00)
  • 2.5" Drive Bays 1 (MCY-B5P2-KWGN-00)
  • 2.5" Drive Bays 2 (MCY-B5S1-KKYA60-05)
  • 2.5" Drive Bays 2 (MCY-B5S1-KWYN-04)
  • 2.5" Drive Bays 2 (MCY-B5S1-KWNN-03)
  • 2.5" Drive Bays 1 (MCY-B5S1-KWYN-02)
  • 2.5" Drive Bays 1 (MCY-B5S1-KKNN-01)
  • UPC Code MCY-B5S1-KKNN-01 / 884102027789
  • UPC Code MCY-B5S1-KWYN-02 / 884102027819
  • EAN Code MCY-B5S1-KKNN-01 / 4719512050705
  • EAN Code MCY-B5S1-KWYN-02 / 4719512050736
  • UPC Code MCY-B5S1-KWNN-03 / 884102027802
  • UPC Code MCY-B5S1-KWYN-04 / 884102027796
  • EAN Code MCY-B5S1-KWNN-03 / 4719512050729
  • EAN Code MCY-B5S1-KWYN-04 / 4719512050712
  • UPC Code MCY-B5S1-KKYA60-05 / 884102027765
  • UPC Code MCY-B5P2-KWGN-00 / 884102036194
  • EAN Code MCY-B5S1-KKYA60-05 / 4719512050682
  • EAN Code MCY-B5P2-KWGN-00 / 4719512063514
  • Model Number MCY-B5S1-KKYA60-05
  • Model Number MCY-B5S1-KWYN-04
  • Model Number MCY-B5S1-KWNN-03
  • Model Number MCY-B5S1-KWYN-02
  • Model Number MCY-B5S1-KKNN-01
  • Model Number MCY-B5P2-KWGN-00
