Hyper 212 ARGB image number 0
Hyper 212 ARGB image number 1
Hyper 212 ARGB image number 2
Hyper 212 ARGB image number 3
Hyper 212 ARGB
Hyper 212 ARGB
Hyper 212 ARGB
Hyper 212 ARGB
Hyper 212 ARGB
The acclaimed Hyper 212 has been complemented with a vibrant ARGB feature. The Hyper 212 ARGB not only provides the best balance for cooling performance with the SickeFlow 120 ARGB fan, but also brightens up your build with eye-catching lighting. The addressable RGB fan is compatible with an array of certified motherboards. Utilizing exclusive Direct Contact Technology and 4 heat pipe arrangement the contact surface provides effective cooling and heat dissipation capable of handling elevated temperatures. The Hyper 212 ARGB is the distinct performance we all know with an equally striking display.
Buy Now
SickleFlow 120 ARGB
Redesigned curved blades and frame optimizes airflow and static pressure with customizable lighting
Mini Addressable RGB Led Controller
Included Mini ARGB controller gives you versatility for your favorite color arrays.
Precision Fin Air Flow
Stacked fin array provides low airflow resistance allowing cooler air flow through the heatsink
Direct Contact Technology using 4 copper heat pipes deliver exceptional heat dissipation
CPU COMPATIBILITY
  • Product Number RR-2V2L-18PA-R1
  • Color Black & Silver
  • Dimensions (L x W x H) 120 x 80.5 x 157 mm / 4.7 x 3.2 x 6.2 inch
  • Fan Quantity 1 PC
  • Fan Speed 650-1800 RPM ± 5%
  • Fan Airflow 62 CFM (Max)
  • Fan Air Pressure 2.5 mmH2O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Noise Level 27 dBA (Max)
  • Fan Rated Current 0.15A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.8W
  • Note AM5 and LGA 1700 mounting kits are included from New Package Design. You may obtain the required mounting kits for products with older package design through the CM store, regional resellers or distributors. Older CPU sockets (LGA 2066, LGA2011-v3, LGA2011, LGA1366, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1) will not be supported anymore from New Package Design.
  • Series Hyper
  • Cooler Type Air Cooler
  • Heatpipes 4
