Elite Gold 1000 image number 0
Elite Gold 1000 image number 1
Elite Gold 1000 image number 2
Elite Gold 1000 image number 3
Elite Gold 1000
Elite Gold 1000
Elite Gold 1000
Elite Gold 1000
Elite Gold 1000
• Supports ATX 3.1 and PCIe Gen 5.1 standards
• Ideal for RTX 50 GPUs
• Stable performance under high loads at up to 40°C
• Quiet, long-life FDB fan cooling
• 1000W output with 80 Plus Gold-certified efficiency
• Fully modular embossed cable design
• Reliable 10-year warranty
ESSENTIAL GOLD POWER FOR EVERYDAY GAMING BUILDS
Cooler Master Elite Gold 1000 is designed for everyday gaming and first-time builds. With full ATX 3.1 compliance support, it's ready for RTX 50 GPUs and future upgrades. Enjoy 80 Plus Gold efficiency, reliable up to 40°C operation, and quiet FDB fan cooling. Fully modular embossed cables simplify installation, dual EPS connectors provide wide compatibility, and a 5-year warranty ensures long-term confidence and reliability.
High Temperature Resilience
Operates reliably at up to 40°C, perfect for extended gaming, rendering, and overclocking.
COMPATIBLE WITH ATX 3.1 AND PCIE GEN 5.1
ATX 3.1 delivers tighter voltage and current regulation with peak power support up to 200% of rated output. Elite Gold 1000 meets the full spec and supports PCIe Gen 5.1 for stable, next-gen performance with RTX 50 GPUs and future high-power cards.
QUIET FDB FAN
QUIET FDB FAN
The Fluid Dynamic Bearing (FDB) fan delivers stable, long-lasting, and whisper-quiet cooling performance.
Cooler Master Elite Gold 1000 achieves over 90% efficiency at typical loads, helping reduce energy waste and minimize heat generation.
The fully modular design comes with flat black cables that can be tailored to each build, offering enhanced grip and a premium look for easier management and a cleaner overall setup.
  • Product Name ELITE GOLD 1000
  • Model MPW-A001-AFAG
  • Input Current 6 ~ 12A
  • Fan Bearing FDB
  • 80 PLUS Rating 80 PLUS Gold
  • Regulatory cTUV us, CB, CE, FCC, BSMI, EAC, RCM, UKCA, RoHS2.0 , REACH
  • ATX 24 Pin Connectors x1 = 1 (600mm)
  • EPS 4+4 Pin Connectors x2 = 2 (700mm)
  • SATA Connectors x9 = 3 (500+100+100mm)
  • Peripheral 4 Pin Connectors x3 = 1 (500+100+100mm)
  • PCI-e 6+2 Pin Connectors x6 = 3 (550+120mm)
  • 12+4 Pin Connectors x1 = 1 (600mm)
  • Series Elite Series
  • Watts 1000W
  • 80 Plus Efficiency Gold
  • Warranty 10 Years
