COSMOS C700P Black Edition image number 0
COSMOS C700P Black Edition image number 1
COSMOS C700P Black Edition image number 2
COSMOS C700P Black Edition image number 3
COSMOS C700P Black Edition image number 4
COSMOS C700P Black Edition image number 5
COSMOS C700P Black Edition image number 6
COSMOS C700P Black Edition image number 7
COSMOS C700P Black Edition image number 8
COSMOS C700P Black Edition image number 9
COSMOS C700P Black Edition image number 10
COSMOS C700P Black Edition image number 11
COSMOS C700P Black Edition image number 12
COSMOS C700P Black Edition image number 13
COSMOS C700P Black Edition image number 14
COSMOS C700P Black Edition image number 15
Raising the Bar(s)
Expanding the COSMOS, Highly Versatile Layout, Extensive Cable Cover System, Rich Connectivity
Expanding the Cosmos
Upgraded Cover System
The PSU Shroud advances in modularity with two independent parts while the cable cover system features 3 separate pieces, each with the capability of mounting storage or a pump for liquid cooling.
Flat Radiator Brackets
Flat radiator brackets offer an easier maintenance, mounting, and removal process for liquid cooling with more clearance for push-pull configurations.
Our Achievements
17 Awards
Curved Tempered Glass Side Panel
A lightly-tinted tempered glass side panel with two curved edges
offer a wide view of the system build.
Rich Connectivity
Ports & Slots
Rich Connectivity
The advanced I/O panel comes with a 4-Pole headset jack (audio+mic), dedicated mic jack, USB 3.1 (Gen 2) Type-C port, four additional USB 3.0 ports, PWM fan speed button, and an addressable RGB control button.
Design
HIGHLY VERSATILE LAYOUT
The unique frame design supports a conventional, chimney, inverse
layout, or a fully customized layout. The motherboard tray is also
removable for installation outside of the chassis.
Cooling Support
16
radiator slots
Cooling Support
18
fan slots
Alternate Rear Panel
To support exotic layouts with motherboards or graphics card oriented vertically, an alternate panel with rubber grommets is included to allow a pass-through for external cables.
EXTENSIVE CABLE COVER SYSTEM
The 3 included covers can be placed on either the M. Port or on the mid-plate, with the ability to mount SSD storage or a reservoir.
  • Size Full Tower
  • Materials Steel
  • Radiator Support - Bottom 120mm
  • Dust Filters Top
  • Dimensions (L x W x H) 639 x 306 x 651mm
  • Fan Support - Bottom 2x 120/140mm*
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • Radiator Support - Front 420mm (requires removal of ODD cage)
  • Pre-installed Fans - Front 2x 140mm, 1200RPM
  • Lighting Support RGB Control Board
  • Dust Filters Front
  • Radiator Support - Bottom 140mm
  • Radiator Support - Rear 140mm
  • Color(s) Black
  • 5.25" Drive Bays 1
  • Radiator Support - Bottom 240mm
  • Dust Filters Bottom
  • Lighting Support 1x RGB Connection
  • Fan Support - Top 3x 120/140mm
  • Expansion Slots 8
  • Radiator Support - Top 280mm
  • I/O Panel 4x USB 3.0
  • Series COSMOS Series
  • Motherboard Support E-ATX
  • Motherboard Support ATX
  • Clearance - GFX 320mm (w/ 3.5" HDD cage)
  • 2.5" / 3.5" Drive Bays (Combo) 4
  • I/O Panel 1x USB 3.1 Gen 2 Type-C
  • Clearance - CPU Cooler 198mm
  • Radiator Support - Top 360mm & 420mm (remove ODD, maximum thickness clearance 70mm)
  • I/O Panel 1x 3.5mm Mic Jack
  • 2.5" Drive Bays 4
  • I/O Panel Fan Speed
  • I/O Panel RGB Control Buttons
  • Clearance - GFX 490mm (w/o 3.5" HDD cage)
  • Weight 22.2 kg
  • Materials Curved Tempered Glass
  • Model Number MCC-C700P-KG5N-S00
