LED Controller A1 image number 0
LED Controller A1 image number 1
LED Controller A1 image number 2
LED Controller A1 image number 3
LED Controller A1 image number 4
LED Controller A1
LED Controller A1
LED Controller A1
LED Controller A1
LED Controller A1
Small, Simple, Versatile
LED Controller A1
Simple and Compact
Backwards Compatibility
MasterPlus+ software
Buy Now
LED Controller A1
Cooler Master has engineered the new Addressable Gen 2 RGB LED Controller granting you the versatility to easily personalize your devices delivered to you in a small compact size.
Simple And Compact
No need to hassle with an ARGB capable motherboard or complex software. With 3 ARGB headers available, each header can connect up to 80 individual LEDs for a total of up to 240 LEDs.
A. 5V SATA Power Connector
B. 9 Pin USB Connector
C. 5V 3 Pin ARGB Connector
Compatible with both Gen 2 ARGB and standard ARGB devices, connect all your devices with the simple touch of a button.
New Addressable Gen 2 RGB
Addressable Gen 2 RGB controller works with Cooler Master's MasterPlus+ software, allowing you to customize each individual LED's color, effect, brightness, and more – all from an intuitive, convenient interface.
  • Product Number MFY-ACBN-NNUNN-R2
  • Color Black
  • Material Plastic
  • Dimensions (L x W x H) 84.7 x 51.7 x 15.3 mm / 3.3 x 2.0 x 0.6 inch
  • Connector 3 ports x 3 Pin Addressable RGB
  • Rated Voltage 5 VDC
  • Safety Current 2.0 (1 port) / Total 4.5 A (3 port)
  • Power Connector SATA
  • Power Safety Current 4.5 A (Max)
  • USB Micro USB x 1
  • Weight 90g / 0.2lbs
  • Cooler Type RGB Accessories
