Cooler Master has established its esteemed reputation in the PC components industry by continuously innovating and pushing the envelope further to produce ever-new technologies that underpin constant improvements in performance and efficiency. Nowhere is this truer than in our cooling product line up. The Mobius series is Cooler Master’s next gen flagship case fan series, researched and designed totally in-house and featuring all the cutting-edge technological improvements that such a forward-thinking product series requires. Let’s dig into the details of some of the components that make the Mobius our best series of case fans yet.
Loop dynamic bearing
The Mobius series features our ultra-quiet, proprietary loop dynamic bearing design, created originally by Cooler Master Corp, our indus
try-facing segment of the company. The purpose of the loop dynamic bearing is to reduce the fan’s vibrations and overall noise level efficiently and effectively while also increasing its life expectancy.
We achieved this through several key technologies. First is the bearing’s oil reflow system. The bearing’s shaft rotates, causing oil to slowly flow to the top of the bearing via centrifugal force. When the oil reflow system first takes in oil, the oil slowly accumulates in a groove and then flows back into the bearing via gravity. The powdered, granular surface of the bearing ensures the oil is evenly and fully integrated, keeping the bearing constantly well-oiled.
