• Products
    ProductsProducts
    • Cooling
      CoolingCooling
      • Air Cooling
      • Liquid Cooling
      • Case Fans
      • Thermal Paste
      • Laptop Cooling
      • Standard Cooler
      • Phone Cooler
    • PC Cases
      PC CasesPC Cases
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • PC Case Accessories
    • Power Supplies
      Power SuppliesPower Supplies
      • X Series
      • V Series
      • V SFX Series
      • GX Series
      • MWE Series
      • Elite Series
    • Accessories
      AccessoriesAccessories
      • Monitors
      • Keyboard
      • Mice
      • Audio
      • Mouse pads
      • Controllers
    • Furniture
      FurnitureFurniture
      • Chairs
      • Desk
      • Accessories
    • Systems
      SystemsSystems
      • MasterHub
        MasterHubMasterHub
        • MAX
          MAXMAX
          • ATX
          • Mini ITX
        • Immersive Experience
          Cooling
          360 DEGREES OF COOL
          PC Cases
          CREATED ONLY FOR THE BEST
          Power Supplies
          PRECISE SILENT POWER
          Furniture
          RELAXATION AT YOUR COMMAND
          Systems
          COOL. COMPACT. QUIET.
          MasterHub
          MAX
        • Builder's Zone
          Builder's Zone
          • PSU Calculator
          • CPU Compatibility
          • Guide & Resources
          Builder's Zone
        • Software
          Software
          • Masterplus+
          • Masterctrl
          Software
        • Support
          Support
          • Product registration
          • Tech support
          • Warranty
          • Warranty check
          • Faq
          • Contact us
          Support
          Special Announcement
        MasterAccessory Riser Cable PCIe 4.0 x16 200mm V2
        Overview
        1. Home/
        2. PC Cases/
        3. Pc Cases Accessories/
        4. MasterAccessory Riser Cable PCIe 4.0 x16 200mm V2
        Flex Your Graphics Muscle
        PCIe 4.0 Compatible
        Ultra Durable PCB
        Heavy Duty Shielding
        Gold-Plated Pin Connections
        Protective ABS Casing
        Ultra-Flexible Cable Sleeves
        FLEX YOUR GRAPHICS MUSCLE
        AVAILABLE IN BOTH BLACK AND WHITE COLORATIONS
        Cooler Master's premium PCIe4.0 Riser Cables V2 are available in both BLACK and WHITE so you can choose the color that best matches your setup!
        PCIE 4.0 COMPATIBLE
        HEAVY DUTY SHIELDING
        GOLD-PLATED PIN CONNECTIONS
        NEW PROTECTIVE ABS CASING
        NEW ULTRA-FLEXIBLE CABLE SLEEVES
        FLEX YOUR GRAPHICS CARD MUSCLE
        The Cooler Master Riser Cable PCIe 4.0 x16 V2 is designed for greater data transmission efficiency, maximum flexibility and durability. High quality plastics grant increased cable flexibility and strength for the tightest PCI card installations, while the heavy-duty shielding prevents electromagnetic interference from degrading signal quality.
        The multi-layer coated PCB provides the best-in-class cable flex, moisture resistance and performance under high thermal loads.
        Trending
        Hyper 212 Halo Black
        Discover
        MasterLiquid 360 ION
        EXPERIENCE COOLING IN HIGH DEFINITION
        Discover
        MasterBox 600
        Powering Next generation
        Discover
        MWE Gold 850 - V2 Full Modular
        Discover
        • About
          Corporate
          Social Media
          News
          Events
        • Support
          Product Registration
          Tech Spec
          Warranty
          Warranty check
          Faq
          Contact us
          Contact Our Team
        CAREER
        RESOURCE CENTER
        • Privacy policy
        • Terms of use
        • Cookie policy
        • Conformity of products
        Confirm your Country
        The page you're looking shows Cooler Master contents for India.
