Small size, big performance. The QUBE 540 supports GPUs up to 415 mm, 360 mm liquid coolers, and high-end components.
Flexible Orientation Design
Vertical or horizontal, the QUBE 540 adapts to your space and style. It fits cleanly wherever you place it.
A modular interior designed for endless creativity, for liquid-cooling setups to compact workstations. Customize it your way.
