A Legendary Cooler, Evolved
The Cooler Master Hyper 212 has long been the reliable choice for solid, no-fuss cooling, trusted by professionals around the world. The new Hyper 212 3DHP Black takes that reputation even further. Its proprietary 3DHP Technology transfers heat away from the CPU more efficiently, rivaling the performance of conventional four-heat-pipe coolers. Using just two heat pipes, it’s engineered to maintain optimal processor temperatures under heavy workloads.
Designed for every PC builder, the Hyper 212 3DHP Black delivers reliable cooling with stylish flair. Built for easy installation and consistent performance, it’s your ideal starting point for cool, quiet computing.
Less heat pipes. More cooling efficiency.
Less noise. More reliability.
