More Balance, More Burst
Mobius 120P ARGB White Edition
Ring Blade Design (RBD)
Pressure Air Acceleration
Absolute Acoustics
Luminescent Light Effects
Addressable Gen 2 RGB
£25.99
PERFECTING ENGINEERING
Cooler Master’s Mobius 120P ARGB White Edition is our new series of performance fans. With our enhanced Ring Blade Design, the Mobius Series optimizes both performance and acoustics, catering to a dynamic range of applications from case, liquid or air, to overclocking and intense gaming.
RING BLADE DESIGN (RBD)
PRESSURE AIR ACCELERATION
Angled inner frame rim with chamfered side vents boost airflow draw, maximizing force induced air pressure and diminishing dead air.
LOOP DYNAMIC BEARING
ANTI-VIBRATION DAMPER
ABSOLUTE ACOUSTICS
Sound output fine tuned to the optimal prominence ratio
to achieve sub 6dB noise levels without performance sacrifice.
Acoustic Testing
Anechoic Chamber for ISO 3745
• Sound Pressure: IS0-7779
• Sound Power: ISO-7779
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
