New
360 Degrees of Cool
MasterLiquid Core II Series
Dual Chamber Pump​
Innovative Design​
Easy Installation​
Universal Socket Support​
Optimum Tubing Length
Series
£67.00
Introducing the redesigned MasterLiquid Core II Series from Cooler Master. Built on the trusted foundation of the MasterLiquid series, the Core II brings improved cooling performance with its upgraded dual chamber pump and wider CPU compatibility for flexible PC builds. With the infinity mirror pump cover design, upgraded fans, and optimized tubing for easy installation, the MasterLiquid Core II Series is a smart and stylish cooling solution for mainstream users looking to step up their setup.
3 x 120mm fans
MasterLiquid Core II 360 Black ARGB​
3 x 120mm fans
MasterLiquid Core II 360 White ARGB​
2 x 120mm fans
MasterLiquid Core II 240 Black ARGB​
2 x 120mm fans
MasterLiquid Core II 240 White ARGB
Innovative Design​
An infinity mirror pump cover design brings stylish lighting and a modern touch to your build​.
Dual chamber pump
Patented design
Improved Quality
Dual Chamber Pump​
Our patented dual chamber design delivers a compact cooler with efficient and reliable performance.
Optimum Tubing Length​
400 mm tubing allows for effortless cooler installation in any orientation.
Easy Installation​
With pre-installed fans, streamlined cabling, pre-applied thermal paste, and pre-mounted brackets, setup is quick, clean, and effortless.
Broad compatibility with both Intel and AMD CPU sockets​.
Pre-Applied CryoFuze Thermal Paste​
Tube Clips Included
