Raising the Bar(s)
COSMOS C700P Black Edition
Expanding the COSMOS, Highly Versatile Layout, Extensive Cable Cover System, Rich Connectivity
£349.00
Expanding the Cosmos
Upgraded Cover System
The PSU Shroud advances in modularity with two independent parts while the cable cover system features 3 separate pieces, each with the capability of mounting storage or a pump for liquid cooling.
Flat Radiator Brackets
Flat radiator brackets offer an easier maintenance, mounting, and removal process for liquid cooling with more clearance for push-pull configurations.
Our Achievements
17 Awards
Curved Tempered Glass Side Panel
A lightly-tinted tempered glass side panel with two curved edges
offer a wide view of the system build.
Ports & Slots
Rich Connectivity
The advanced I/O panel comes with a 4-Pole headset jack (audio+mic), dedicated mic jack, USB 3.1 (Gen 2) Type-C port, four additional USB 3.0 ports, PWM fan speed button, and an addressable RGB control button.
Design
HIGHLY VERSATILE LAYOUT
The unique frame design supports a conventional, chimney, inverse
layout, or a fully customized layout. The motherboard tray is also
removable for installation outside of the chassis.
Cooling Support
16
radiator slots
Cooling Support
18
fan slots
Alternate Rear Panel
To support exotic layouts with motherboards or graphics card oriented vertically, an alternate panel with rubber grommets is included to allow a pass-through for external cables.
EXTENSIVE CABLE COVER SYSTEM
The 3 included covers can be placed on either the M. Port or on the mid-plate, with the ability to mount SSD storage or a reservoir.
Motherboard Support
Mini-ITX
Micro-ATX
ATX
E-ATX*
*E-ATX up to 12" x 10.7" may impact cable management options.
Storage Support
5.25” ODD X 1
3.5” / 2.5” COMBO X 4
2.5” SSD X 4
Upgradeable to 12x 3.5“ HDD
