A New Type of Reinforcement
Tempered glass, addressable RGB, and edge-lighting technology all crammed into a not-so-simple graphics card support bracket. Sure, GPU brackets are an important tool in keeping your motherboard’s PCI-e slot safe from sag but we bet you didn’t expect it to be the new centerpiece to your build.
The MasterAccessory ARGB GPU Support Bracket utilizes the strength and aesthetic of tempered glass in completely new ways. The strength of the TG supports the biggest, baddest cards out there. The CNC machining provides edge-lit ARGB. The universal design of the support arm offers hassle-free adjustment, by sliding and locking in place, to fit a high range of graphics card and PC case combinations. If your build is on the subtler side, switch off the lighting for an elegant, invisible GPU support bracket.
Equal parts functional and artistic, the MasterAccessory ARGB GPU Support Bracket keeps your PCI-e slots safe as effectively as it keeps you staring at your glorious build for way too long.
