Same Legend, More Edge
SickleFlow Edge 120 ARGB 3-Pack Fan Kit
  • Enhanced Fan Blade
  • Redesigned Fan Frame
  • Improved bearing system
  • A1 Mini LED Controller
€41.99
SAME LEGEND, MORE EDGE
The SickleFlow Edge 120 ARGB 3-Pack Fan Kit features an enhanced fan blade, a newly redesigned frame, a novel bearing system, and an ARGB gen 2 mini controller for maximal performance and triple the power.
Enhanced Fan Blade
An improved fan blade provides higher fan speed, air pressure, and airflow while sticking to the same low noise level the SickleFlow is known for.
REDESIGNED FAN FRAME
The SickleFlow’s signature lines are now included in the frame design to provide a more cohesive product design.
IMPROVED BEARING SYSTEM
An enhanced loop dynamic bearing system keeps things running silently smooth.
A1 MINI LED CONTROLLER
Control and customize your SickleFlow Edge 120 Fan Kit's lighting with a compact, easy-to-use mini controller.
