More Balance, More Burst
MOBIUS 120 SLIM
Ring Blade Design (RBD)
Pressure Acceleration Air Vents
Thin frame design
Upgraded three-phase motor
€19.99
€15.00
--27%
PERFECTING THE ENGINEERING
Cooler Master’s is Introducing the latest innovation in Cooler Master’s critically-acclaimed Mobius case fan series: the Mobius 120 Slim. This updated model has been redesigned with a thinner frame, perfect for small form factor builds that have limited space but need more airflow. Features such as an interconnecting ring blade design accelerated pressure air vents, and an upgraded three-phase motor ensure exceptional stability and silent performance. Want to really stack your build with multiple GPUs, or maybe customize your case with figures? Then you’ll need to free up space while still keeping things cool. Trim down your build with the Mobius 120 Slim.
Interconnecting fan blades designed for a reinforced and rigid structure, eliminating vibration for stable, fluid fan operation.
LOOP DYNAMIC BEARING
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
The angled inner frame rim with chamfered side vents boosts airflow draw. The structural ring blade eliminates fan deformation, keeping the fan's build rigid.
UPGRADED THREE-PHASE MOTOR
The Mobius 120 Slim ensures top-notch stability even at high speeds, providing consistent and reliable cooling performance at low noise levels.
THIN FRAME DESIGN
The 15mm thickness allows the fan to fit into cases where standard 25mm fans cannot. This is particularly useful in slim or compact cases, such as ITX or SFF builds and a low-profile CPU cooler.
