New
Premium modular ATX case
MasterFrame 600
Premium open-frame ATX case designed for modular builds, extreme cooling, and total customization through the Freeform 2.0 platform.
€199.00
MasterFrame 600
The MasterFrame 600 is a premium open-frame mid-tower chassis built for high-performance hardware, extreme cooling, and total customization. Designed with Freeform 2.0 in mind, it supports ATX to E-ATX motherboards and offers full access to modular design files, empowering users to build and evolve without limits.
Silver
Rear Sickleflow 120 ARGB PWM Fans,
Triple Sickleflow 140 ARGB PWM Fan,
Triple 360mm Radiator support,
Tempered Glass side,
USB 3.2 Type-C,
Support GPU length 485mm
Black
Rear Mobius 120 PWM Fans,
Triple Mobius 140 PWM Fan,
USB 3.2 Type-C,
FreeForm 2.0
Exo-structure
The exposed frame structure enhances chassis adaptability and provides flexible configuration options for various scenarios.
Versatile & Maker-Driven
Its open source design and interchangeable panels offer endless personalization possibilities, transforming your chassis into a unique expression of style.
Flexible Motherboard Support
Supports Mini-ITX to E-ATX motherboards, offering compatibility with a wide range of builds and configurations.
Extensive Cooling Support
Can house up to eleven fans and multiple radiator sizes (up to 420mm), ensuring superior thermal performance.
Ample GPU Clearance
Accommodates graphics cards up to 485mm, offering plenty of space for high-end GPUs.
Tool-Free Panel Removal
Easily remove side panels and other components without tools for quick access and modifications during build or upgrades.
Included GPU support bracket
The included GPU support bracket prevents GPU sag and ensures stability during intense gaming or high-performance workloads, maintaining a clean and secure build.
Customization
Swappable Panel
*Availability may differ based on region
Ebony
Eucalyptus
GreyOak
StoneVeneer
Walnut
MasterFrame Series
