A Dual New World
MasterFan MF120 Halo² 3in1
The MasterFan MF120 Halo² is our redesigned dual loop LED series fan, now available as a 3-in-1 pack, giving you triple the cooling power.
€54.99
A DUAL NEW WORLD
The MasterFan MF120 Halo² is our redesigned dual loop LED series fan, now available as a 3-in-1 pack, giving you triple the cooling power. The MF120 features 10% larger fan blades for improved air flow and cooling performance. The frame has been designed with a hybrid structure that maintains stability without sacrificing operational real estate. An upgraded driver IC is also included for increased cooling performance and minimal fan noise, while the elegant dual loop LED design is maintained via addressable gen 2 RGB lighting that provides the ultimate customizable experience. Enter a dual new world with the the MasterFan MF120 Halo².
HYBRID FRAME DESIGN
A hybrid frame structure maintains stability without sacrificing fan blade size or performance.
LED CONTROLLER
UPGRADED DRIVER IC
An upgraded driver IC boosts cooling performance while minimizing fan noise.
