NCORE 100 MAX Bronze + GA2701S
The NCORE 100 Max leverage decades of expertise in thermal solutions and features a custom 120mm AIO Water Cooler supporting the latest Intel and AMD CPUs.
Includes support for high performance, triple-slot GPUs up to 336mm in length and 140mm in height, with four included 6+2 pin power cables and a vertical mount design.
Cooler Master's V SFX Gold 850W ATX 3.0 PSU covers all your power needs and comes with custom length cables.
The NCORE 100 MAX is super compact, with a footprint about the size of a small booklet.
An anodized aluminum shell makes the NCORE 100 MAX stand out as a desktop work of art.
FIND YOUR BALANCE
GA2701S utilizes a 27-inch 1920 x 1080 FHD panel providing extra workspace at the 'default' resolution. Striking a great balance between resolution and screen size, the GA2701S is perfect for both work and play.
