• Shop Now
    Shop Now
    • Prebuilt Gaming PCs
    • Online Store
    • Special Deals
    Shop Now
    Online Store
  • Products
    ProductsProducts
    • Cooling
      CoolingCooling
      • Air Cooling
      • Liquid Cooling
      • Case Fans
      • Thermal Paste
      • Laptop Cooling
      • Standard Cooler
      • Phone Cooler
      • Accessories
    • PC Cases
      PC CasesPC Cases
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • PC Case Accessories
    • Power Supplies
      Power SuppliesPower Supplies
      • X Series
      • V Series
      • V SFX Series
      • GX Series
      • MWE Series
      • Elite Series
    • Accessories
      AccessoriesAccessories
      • Monitors
      • Keyboard
      • Mice
      • Audio
      • Mouse pads
      • Controllers
    • Furniture
      FurnitureFurniture
      • Chairs
      • Desk
      • Accessories
    • Systems
      SystemsSystems
    • MasterHub
      MasterHubMasterHub
      • MAX
        MAXMAX
        • ATX
        • Mini ITX
      • Immersive Experience
        Cooling
        360 DEGREES OF COOL
        PC Cases
        CREATED ONLY FOR THE BEST
        Power Supplies
        PRECISE SILENT POWER
        Furniture
        RELAXATION AT YOUR COMMAND
        Systems
        COOL. COMPACT. QUIET.
        MasterHub
        MAX
      • Builder's Zone
        Builder's Zone
        • PSU Calculator
        • CPU Compatibility
        • Guide & Resources
        Builder's Zone
      • Software
        Software
        • MasterHUB
        • Masterplus+
        • Masterctrl
        Software
      • Support
        Support
        • Product registration
        • Tech support
        • Warranty
        • Warranty check
        • Faq
        • Contact us
        • Return Policy
        • Shipping Policy
        Support
        Special Announcement
      1. Home/
      2. Guide & Resources/
      3. What is 80 Plus efficiency?
      WHAT IS 80 PLUS EFFICIENCY?
      In the process of determining what PSU is right for your PC build, you are confronted with a range of aspects to consider such as form factor, wattage, and efficiency. Efficiency is a special case, as it can be hard to know what makes a PSU efficient. That’s where the 80 Plus certification program comes in. In this article, we will go over some basics of PSU efficiency and discuss in detail the 80 Plus certification levels. You might have heard of PSUs being “Gold certified” or having “Platinum efficiency”, and in this article we are going to get into the details of what those terms mean.
      in this article
      • What is 80 Plus, exactly?
      • What 80 Plus efficiency rating should I look for?
      Before we dive into the specifics of 80 Plus certification, you may be wondering: why should I care about PSU efficiency? Efficient PSUs make less noise and usually feature higher quality, longer lasting components. In short, the more efficient a PSU is, the less money you will spend on electricity and new components.
      80 Plus is a voluntary certification program that PSU manufacturers can participate in to prove the efficiency of their units. For a unit to be considered for certification at all, it must achieve at least 80% efficiency at 20%, 50%, and 100% loads and feature a power factor of at least 0.9 at 100% load. This is the basic 80 Plus certification. As the certification levels go higher, higher numbers are required. For example, to achieve a Bronze level certification, a unit must achieve 82%, 85%, and 82% efficiency at 20%, 50%, and 100% loads, respectively. See the table below for a full breakdown of each certification level’s requirements:
      Sometimes, particularly efficient units can also perform beyond the bounds of these levels. For example, Cooler Master’s GX III Gold 850 can achieve Titanium level efficiency at 10% and 20% loads, making it more efficient that the average Gold rated unit.
      The Platinum level tends to be a good balance between efficiency, performance, and price. A Platinum rated PSU is highly efficient but goes easy on your bank account. Cooler Master has recently released two Platinum rated PSUs, the V Platinum V2 and the V SFX Platinum. Both units are thus rated to achieve 89% efficiency at 100% loads, ultimately saving you a lot of money each month.
      So which efficiency level should you look for in your PSU? Regardless of what kind of PC you are building, you are going to want to aim for the most efficient PSU you can, and often a Platinum level PSU is a good choice. However, some PSUs with other certifications such as the 80 Plus Gold rated GX III Gold can achieve up to Titanium level efficiency depending on the load. This means that reading the details of each PSU’s 80 Plus efficiency rating and performance is key so that you may make the correct and informed decision for your build. If you’d like more info on Cooler Master’s own range of PSUs such as the GX III Gold, V Platinum V2, and the V SFX Platinum, please check them out here.
      • About
        Corporate
        Social Media
        News
        Events
      • Support
        Product Registration
        Spare Parts Store
        Tech Spec
        Warranty
        Warranty check
        Faq
        Contact us
      CAREER
      RESOURCE CENTER
      • Privacy policy
      • Terms of use
      • Cookie policy
      • Conformity of products
      Confirm your Country
      The page you're looking shows Cooler Master contents for European Union.
