• Products
    ProductsProducts
    • Cooling
      CoolingCooling
      • Air Cooling
      • Liquid Cooling
      • Case Fans
      • Thermal Paste
      • Laptop Cooling
      • Standard Cooler
      • Phone Cooler
      • Accessories
    • PC Cases
      PC CasesPC Cases
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • PC Case Accessories
    • Power Supplies
      Power SuppliesPower Supplies
      • X Series
      • V Series
      • V SFX Series
      • GX Series
      • MWE Series
      • Elite Series
    • Accessories
      AccessoriesAccessories
      • Monitors
      • Keyboard
      • Mice
      • Audio
      • Mouse pads
      • Controllers
    • Furniture
      FurnitureFurniture
      • Chairs
      • Desk
      • Accessories
    • Systems
      SystemsSystems
      • MasterHUB
        MasterHUBMasterHUB
        • MAX
          MAXMAX
          • ATX
          • Mini ITX
        • Immersive Experience
          Cooling
          360 DEGREES OF COOL
          PC Cases
          Premium Modular ATX Case
          Power Supplies
          PRECISE SILENT POWER
          Furniture
          RELAXATION AT YOUR COMMAND
          Systems
          COOL. COMPACT. QUIET.
          MAX
        • Builder's Zone
          Builder's Zone
          • PSU Calculator
          • CPU Compatibility
          • Guide & Resources
          Builder's Zone
        • Software
          Software
          • MasterHUB
          • Masterplus+
          • Masterctrl
          Software
        • Support
          Support
          • Product registration
          • Tech support
          • Warranty
          • Warranty check
          • Faq
          • Contact us
          Support
          Special Announcement
        MM712 Wired Gaming Mouse
        Overview
        1. Home/
        2. Accessories/
        3. Mice/
        4. MM712 Wired Gaming Mouse
        MM712 Wired Gaming MouseMM712 Wired Gaming Mouse
        Legendary Gaming Mouse – Fast, Precise, and Superlight
        Step into the realm of legends with the MM712 Wired Gaming Mouse. Dominate the game, seize victory, and leave your mark as an unstoppable force in the gaming universe. Elevate your gameplay and your mastery. The MM712 is reborn with an improved shape, enhanced accessibility, precision, and weight. Whether it’s repetitive work clicks or fast, accurate shots, the MM712 delivers pixel-perfect accuracy, empowering you to execute flawless maneuvers with pinpoint precision.
        The 49 Gram Legacy – Our Lightest Mouse Yet
        What truly sets the MM712 apart is its class-leading weight. Engineered with a cleverly structured chassis and a superlight frame weighing just 49 grams, this mouse feels like an extension of your hand, effortlessly gliding across your gaming surface. Say goodbye to fatigue during intense gaming marathons—the MM712’s ergonomic design ensures comfort and control through every high-stakes battle and extensive work session.
        Elite Gaming-Grade Optical Sensor
        The MM712 is equipped with a state-of-the-art PAW3395 optical sensor, offering up to 26,000 DPI resolution, 50G acceleration, and 650 IPS max speed. This powerful combination makes it an explosive weapon in any arena.
        Hit It with the Speed of Light
        The MM712 is fitted with two optical micro switches for instant fire and an extended lifetime. Laser sensors do not require the same debounce delay commonly found in traditional switches and register inputs nearly three times faster for almost zero input latency during your game.
        Center Stage
        With feedback from our community of gamers, the MM712 now positions the sensor dead center of its mass, ensuring perfectly balanced weight distribution and a consistent feel during lifts and swipes.
        Zero Pull, Frictionless Glide from Superior PTFE Feet
        Redesigned curved-edge PTFE feet make the MM712 glide effortlessly across any surface with zero cable pull.
        You asked, and we listened! The MM712 features a completely new body and redesigned key contours, including a pronounced finger rest for improved grip and a rising edge chamfer for added comfort for your ring finger.
        The MM712 now features an improved side-button design with chamfered edges to reduce chafing and a wider gap for better accessibility.
        Cooler Master Exclusive Ultraweave Cable
        Exceptionally lightweight and designed for tighter control, Ultraweave eliminates cable snag and reduces drag for quicker and smoother swipes in the heat of the battle.
        The Masterkey with On-Board Safe-Keeping
        The new MasterPlus+ software from Cooler Master unlocks the MM712’s full potential. Adjust your settings, remap buttons, set up macros and profiles, and more. Once configured, all your settings are stored directly on the device, providing a true plug-and-play experience with a set-it-and-forget-it convenience.
        * The software only supports Windows 7 and above.
        Set Your Style, Your Team Colors, Your Mood
        Personalize your mouse in style with 16.7M customizable illuminating RGB colors. Sync colors across all your Cooler Master devices or adjust RGB effects in real time via key combos or MasterPlus+ Software.
        Wheel + Forward = Change LED color
        Wheel + Backward = Cycle LED modes
        Trending
        New
        MasterFrame 600
        Premium modular ATX case
        Discover
        • About
          Corporate
          Social Media
          News
          Events
        • Support
          Product Registration
          Tech Spec
          Warranty
          Warranty check
          Faq
          Contact us
        CAREER
        RESOURCE CENTER
        • Privacy policy
        • Terms of use
        • Cookie policy
        • Conformity of products
        Confirm your Country
        The page you're looking shows Cooler Master contents for Australia.
