Compuesto de alta conductividad térmica
MasterGel Pro V2
Un compuesto actualizado de su versión anterior con alta conductividad de CPU / GPU, que proporciona una mejor disipación de calor ...
MasterGel Pro V2
HIGH THERMAL CONDUCTIVITY COMPOUND
Upgraded compound for better heat dissipation
High CPU/GPU conductivity (9 W/m.k)
Improves heat transfer from chipset to cooler base or heat pipes
Easy to spread and remove without damaging the surface
High Performance
Upgraded compound improves heat transfer from chipset to cooler base or heat pipes
High Quality
MasterGel Pro V2, an upgraded compound of its old version with high CPU/GPU conductivity, providing better heat dissipation as well as improving heat transfer form chipset to cooler base. Apart from aesthetic design the thermal grease has been adjusted to match your performance needs.
Easy To Spread
W/M.K = 9
